Home » Archived » EMF Store » Cannot find org.unicase.emfstore.server in debug config dialog(Eclipse config trouble for unicase store)
Cannot find org.unicase.emfstore.server in debug config dialog [message #693969] Thu, 07 July 2011 10:54 Go to next message
Question
Can someone let me know how I can get the "org.unicase.emfstore.server" into the Eclipse > Debug Configuraions Dialog > Run a product > drop down list?
Background
I thought I was following the Unicase - "Install EMFStore" video tutorial correctly but when I pull down the list of products to run part of the tutorial, the expected item was missing.
(www<dot>youtube<dot>com/watch?v=fdeswZdpvs0&feature=player_embedded#at=24 )How to install the EMFStore Framework . Time was 3.00 mins into the tutorial.
I went to the Eclipse Modeling Edition Download link given here on the Unicase website (http<colon>//code<dot>google<dot>com/p/unicase/wiki/InstallEMFStore) and I downloaded the modelling version - maybe a mistake(?)
Now I'm confused because I've missed a trick and googling hasn't brought me any other, similar, posted problems to get a hint.
Re: Cannot find org.unicase.emfstore.server in debug config dialog [message #693978 is a reply to message #693969] Thu, 07 July 2011 11:10 Go to previous messageGo to next message
Originally posted by: Jonas Helming
Hi John,
EMFStore has moved to Eclipse. We are currently transfering the content
of the website to the Eclipse site. The Tool UNICASE is currently using
the old "non-Eclipse" version, although it will switch soon. If you are
only interested in EMFStore and not in UNICASE, I kindly ask you to
follow this tutorial:
http://eclipse.org/emf-store/gettingstarted.php
If you are interested in UNICASE and need a server for it, please let me
know again.
Cheers
Jonas
Am 07.07.2011 16:54, schrieb John:
> Question
> down list?
> Background
> tutorial.
> Unicase website
Re: Cannot find org.unicase.emfstore.server in debug config dialog [message #694213 is a reply to message #693978] Fri, 08 July 2011 02:17 Go to previous messageGo to next message
Hi Jonas,
Yes - I'm specifically interested in UNICASE and would like to try the server for it. I would be grateful if you could send me the server for it, thanks.
John
Re: Cannot find org.unicase.emfstore.server in debug config dialog [message #694277 is a reply to message #694213] Fri, 08 July 2011 04:57 Go to previous messageGo to next message
Am 08.07.2011 08:17, schrieb John:
> Hi Jonas,
> it, thanks. John
as I am not an active part of the UNICASE project anymore, may I ask you
to forward your request to either unicase-dev (googlegroups) or narayan
at in.tum.de
Cheers
Jonas
Re: Cannot find org.unicase.emfstore.server in debug config dialog [message #694379 is a reply to message #694277] Fri, 08 July 2011 09:07 Go to previous message
Ok - I will ask the UNICASE googlegroup for assitance. Thanks.
Previous Topic:Namespace changing...
Next Topic:how to make AND operation between two conditions in EmfFacet
Current Time: Sun Jul 27 12:27:09 EDT 2025
Powered by FUDForum. Page generated in 0.04792 seconds
