Home » Language IDEs » ServerTools (WTP) » Problems including dependent projects in Dynamic Web Projects(Neither Tomcat nor Eclipse's local server can run my JSP, presumably due to lack of a dependency)
Problems including dependent projects in Dynamic Web Projects [message #693600] |
Wed, 06 July 2011 16:34  |
I created a Dynamic Web Project, call it A. In it I put a JSP and a Java class, call it AC; the JSP instantiates and uses AC. That Java class extends one from another project, say class BC from project B; project B is an ordinary Java project (which, in turn, depends on some other ordinary Java projects, and so on). When I select my JSP in the Package Explorer and do "Debug As ... > Debug on Server", using "J2EE Preview at localhost" as the server, it fails with the following complaint (in the "Variables" tab in the Debug perspective):
org.apache.jasper.JasperException: Unable to compile class for JSP
Generated servlet error:
The type BC cannot be resolved. It is indirectly referenced from required .class files
I have futzed with various project properties, such that now when I ask Eclipse to generate a WAR for project A, its WEB-INF/lib/ includes a virtual JAR from project B. The first step in that was to open the project properties for A, and include B in the Web Deployment Assembly. That was not sufficient. I then checked the check-box for B in the listing in the "Order and Export" tab of the Java Build Path section of the project properties. That may or may not have been sufficient. Then I created an unrelated EAR project and deleted it. Now WAR export of project A works as you would expect.
I might not have all the projects transitively required at runtime in both the Web Deployment Assembly and checked in the Order and Export list of project A. But the complaint given mentions only the class I am calling BC --- which extends java.lang.Object.
What is going wrong, and/or how can I find out more details about it for myself? How do I fix it?
BTW, when I export a WAR from project A and try to run it in Tomcat 7.0.16, it fails in the JSP compliation step. However, Tomcat only tells me that the compilation failed on the JSP line that instantiates class AC; it does not give any more details.
I am using Eclipse Helios Service Release 2 (Build id: 20110218-0911) on MacOS 10.6.8 on a MacBook Pro (Intel), with
$ java -version
java version "1.6.0_26"
Java(TM) SE Runtime Environment (build 1.6.0_26-b03-384-10M3425)
Java HotSpot(TM) 64-Bit Server VM (build 20.1-b02-384, mixed mode)
Re: Problems including dependent projects in Dynamic Web Projects [message #693923 is a reply to message #693600] |
Thu, 07 July 2011 09:44   |
> $ java -version
I don't think WTP is able to handle dependencies of dependencies. So
adding B as a dependent project of A in Deployment Assembly was correct,
but you will also need to add the Java projects that B depends on. Jar
dependencies can be added to the Java Build Path of project A. In the
Markers view a warning will appear under the Classpath Dependency
Validator Message group. The Quick Fix for that warning can "mark" that
Jar for inclusion in "WEB-INF/lib".
For additional details about the WTP Tomcat support see the Tomcat FAQ[1].
Larry
[1] http://wiki.eclipse.org/WTP_Tomcat_FAQ
Re: Problems including dependent projects in Dynamic Web Projects [message #694223 is a reply to message #693600] |
Fri, 08 July 2011 02:35   |
I actually suspect this guava business is a distraction from my main problem, read the second half of this post.
Like I said, it was in the Dynamic Web Project (which I am calling A here) that I opened the properties sheet and added a Project Reference to guava-r09.
Since reading you latest post, I also made three more changes. First, I opened the properties sheet of Dynamic Web Project A again, went to the Java Build Path section, the Libraries tab, clicked "Add JARs...", navigated to the guava-r09.jar in the guava-r09 project, and added it. Then I went to the Order and Export tab and saw that the guava-r09.jar was now listed there but not checked, so I checked it. After OKing the changes I noticed I now had two markers --- the one I last complained about and also another copy of the one I first mentioned (for which I then did the same QuickFix as before). Now I only have the marker whose properties sheet says
Description: Projects must be referenced by an EAR or a WAR to use classpath publish/export dependencies whose runtime path (../) maps into the parent component.
On element: guava-r09
I really am having trouble seeing what more I can do to Dynamic Web Project A to make guava-r09 happy. Here is the .classpath that I now have for A:
<classpath>
<classpathentry kind="src" path="src"/>
<classpathentry kind="con" path="org.eclipse.jdt.launching.JRE_CONTAINER/org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/J2SE-1.5">
<attributes>
<attribute name="owner.project.facets" value="java"/>
</attributes>
</classpathentry>
<classpathentry kind="con" path="org.eclipse.jst.j2ee.internal.web.container"/>
<classpathentry kind="con" path="org.eclipse.jst.j2ee.internal.module.container"/>
<classpathentry combineaccessrules="false" exported="true" kind="src" path="/B"/>
... the deeper Java project dependencies ...
<classpathentry combineaccessrules="false" exported="true" kind="src" path="/guava-r09"/>
<classpathentry exported="true" kind="lib" path="/guava-r09/guava-r09.jar" sourcepath="/guava-r09/guava-src-r09.zip">
<attributes>
<attribute name="javadoc_location" value="jar:platform:/resource/guava-r09/guava-javadoc-r09.zip!/"/>
<attribute name="org.eclipse.jst.component.dependency" value="/WEB-INF/lib"/>
</attributes>
</classpathentry>
<classpathentry kind="output" path="build/classes"/>
</classpath>
and here is what A's .project has to say about its natures:
<natures>
<nature>org.eclipse.jem.workbench.JavaEMFNature</nature>
<nature>org.eclipse.wst.common.modulecore.ModuleCoreNature</nature>
<nature>org.eclipse.wst.common.project.facet.core.nature</nature>
<nature>org.eclipse.jdt.core.javanature</nature>
<nature>org.eclipse.wst.jsdt.core.jsNature</nature>
</natures>
and, while we're at it, here is the .classpath of guava-r09:
<classpath>
<classpathentry kind="con" path="org.eclipse.jdt.launching.JRE_CONTAINER"/>
<classpathentry exported="true" kind="lib" path="guava-r09.jar" sourcepath="guava-src-r09.zip">
<attributes>
<attribute name="org.eclipse.jst.component.dependency" value="../"/>
</attributes>
</classpathentry>
</classpath>
Having reorganized the code a bit, I again tried to debug my Dynamic Web Project using Eclipse's J2EE preview server. When the JSP was visited by a browser it returned a page that started with the following complaint and continued with stack traces.
HTTP ERROR 500
Problem accessing /A/maker.jsp. Reason:
java.lang.NoClassDefFoundError: B/BC
Re: Problems including dependent projects in Dynamic Web Projects [message #694411 is a reply to message #694223] |
Fri, 08 July 2011 10:04  |
> to guava-r09.
> have for A:
> <classpath>
> <attributes>
> </attributes>
> </classpathentry>
> path="/B"/>
> path="/guava-r09"/>
> <attributes>
> </attributes>
> </classpathentry>
> </classpath>
> <natures>
> </natures>
> <classpath>
> <attributes>
> </attributes>
> </classpathentry>
> </classpath>
> HTTP ERROR 500
My guess at this point is that the problems may be stemming from the
guava-r09 project. Given that the ".classpath" file contains no "src"
<classpathentry>, it suggests that this project simply "holds" the
guava-r09.jar. The presence of the
"org.eclipse.jst.j2ee.internal.module.container" <classpathentry>
indicates the guava-r09 project has been upgraded to be the JavaEE type
project, which WTP supports. I believe that WTP expects its JavaEE
project to actually build something (internally referred to as a
"module"). I'm not sure if "jar holder" projects will work correctly
with WTP. If "guava-r09" is actually a "jar holder" project, then it
would be better if no other project directly referenced this project,
but instead, directly referenced the jar it contains.
If the guava-r09 project is more than just a jar holder, please provide
details about how it was created and what this project is supposed to
create.
Regardless, the "org.eclipse.jst.component.dependency" attribute should
not be present in the guava-r09 ".classpath" file. It's the one
causing the warning. I believe it would only be useful if this project
were directly referenced (via Deployment Assembly) in an EAR project.
Larry
P.S. For testing with Tomcat, you can use the WTP Tomcat FAQ mentioned
earlier to determine where the webapp is being published to see what
Tomcat is actually trying to run. If what you need isn't being
assembled there correctly, it obviously won't work the way you expect.
I'm not sure what is ending up there for guava-r09, if anything.
Current Time: Sun Jul 27 13:45:18 EDT 2025
Powered by FUDForum. Page generated in 0.08188 seconds
