Home » Eclipse Projects » GEF » File chooser in the property sheet
File chooser in the property sheet [message #675523] Tue, 31 May 2011 14:26 Go to next message
I am implementing a workflow editor and I would like to add a file chooser in the property sheet of my application.
For example, when I select a file, I can see its attributes (name, type, ...) and I would like to add its location.
For me, the easiest solution would be to have a "three dots button" on the line File location of the property sheet and when clicking on this button, it would open a file chooser window and save the selected file location in the object's attributes.
Is this possible? How could I do that in another way than enter it manually in the property field?
Thank you.
Greg
[Updated on: Tue, 31 May 2011 14:27] by Moderator
Re: File chooser in the property sheet [message #693825 is a reply to message #675523] Thu, 07 July 2011 05:20 Go to previous messageGo to next message
you can extend PropertyDescriptor and override
public CellEditor createPropertyEditor(Composite parent)
to return an instance of the following class.
public final class FileDialogCellEditor extends DialogCellEditor {
	private final String[] filterNames;
	private final String[] filterExtensions;
	private final String filterPath;
	private final String dialogText;
	public FileDialogCellEditor(Composite parent,
	        		    String[] filterNames,
				    String[] filterExtensions,
				    String filterPath,
				    String dialogText) {
		super(parent);
		this.filterNames = filterNames;
		this.filterExtensions = filterExtensions;
		this.filterPath = filterPath;
		this.dialogText = dialogText;
	protected Object openDialogBox(Control cellEditorWindow) {
		setErrorMessage(null);
		FileDialog dialog = new FileDialog(cellEditorWindow.getShell());
		dialog.setFilterExtensions(filterExtensions);
		dialog.setFilterNames(filterNames);
		dialog.setFilterPath(filterPath);
		dialog.setText(dialogText);
		String absolutePath = dialog.open();
		return absolutePath;
[Updated on: Thu, 07 July 2011 05:24] by Moderator
Re: File chooser in the property sheet [message #758481 is a reply to message #693825] Wed, 23 November 2011 07:27 Go to previous message
Hi Christian,
I have tried your solution, but the Choose button does not appear in the Property Sheet in order to open the Dialog box. Could you please explain further?
Previous Topic:Scaled SWTGraphics draws
Next Topic:GEF documentation is not included on the on-line version of latest release of eclipse help.
Current Time: Fri Jul 18 19:38:33 EDT 2025
Powered by FUDForum. Page generated in 0.04176 seconds
