Home » Eclipse Projects » Eclipse Platform » Disabling build before running ant or external tools
Disabling build before running ant or external tools [message #68527] Mon, 09 June 2003 21:54 Go to next message
Originally posted by: mxlehma.NOSPAM.qwest.com
Is there a way to turn off the running of an eclipse project build before
an ant or external tools command is executed?
If you primarily use ant or an external tool that points to an ant bat
file, then everything essentially gets built twice; once within eclipse,
and then again when ant runs.
Thanks.
Re: Disabling build before running ant or external tools [message #69256 is a reply to message #68527] Tue, 10 June 2003 09:39 Go to previous messageGo to next message
Originally posted by: darin_swanson.oti.com
See the Debug preference for "building before launching".
Turn it off.
HTH
Darins
"Michael" <mxlehma@NOSPAM.qwest.com> wrote in message
news:bc3doh$c4e$1@rogue.oti.com...
> Thanks.
Re: Disabling build before running ant or external tools [message #69362 is a reply to message #69256] Tue, 10 June 2003 10:01 Go to previous message
That did the trick. I knew there had to be a setting somewhere.
Thanks.
> Turn it off.
> HTH
> Darins
> > Thanks.
Previous Topic:tasks
Next Topic:Status Line
Current Time: Mon Nov 03 10:25:10 EST 2025
Powered by FUDForum. Page generated in 0.03524 seconds
