Home » Eclipse Projects » Platform - User Assistance (UA) » Problem with Keyword Index (since 3.7)
Problem with Keyword Index (since 3.7) [message #692871] Tue, 05 July 2011 07:35 Go to next message
Originally posted by:
I provide a keyword index (using the extension point
"org.eclipse.help.index") in my RCP application.
Since I migrated my application (from Eclipse 3.4.1) to Eclipse 3.7
there are problems how links in parent nodes of the keyword tree are
displayed. There is now inserted after each parent node that links a
help page a blank line that also links the defined help page.
For example, a keyword index defined as follows in the index.html:
<index>
<entry keyword="topic_1">
<topic href="doc/topic1.html"/>
<entry keyword="topic_1_1">
<topic href="doc/topic_1_1.html"/>
</entry>
<entry keyword="topic_1_2">
<topic href="doc/topic_1_2.html"/>
</entry>
</entry>
<entry keyword="topic_2">
<entry keyword="topic_2_1">
<topic href="doc/topic_2_1.html"/>
</entry>
</entry>
</index>
... will be shown in the Help View this way:
topic_1 (links to "doc/topic1.html")
<blank line> (links to "doc/topic1.html" as well)
topic_1_1 (links to "doc/topic1_1.html")
topic_1_2 (links to "doc/topic1_1.html")
topic_2 (mouse click opens/closes underlying tree structure)
topic_2_1 (links to "doc/topic2_1.html")
Might this be a bug or has anything changed in recent versions of
Eclipse regarding this extension point?
I've tested this behaviour under Windows 7 and Mac OS X (10.6) and it
occurs on both systems.
Best Regards,
Andreas
Re: Problem with Keyword Index (since 3.7) [message #693145 is a reply to message #692871] Tue, 05 July 2011 18:15 Go to previous messageGo to next message
The blank line sounds like a bug, I have not noticed that during testing, probably there is something different between your index and the one which I am using to test with. Can you file a bug report?
Re: Problem with Keyword Index (since 3.7) [message #693272 is a reply to message #693145] Wed, 06 July 2011 03:23 Go to previous message
Ok, I will file a bug report.
Previous Topic:Cheat Sheet programming issue <onCompletion>
Next Topic:How to share css files between Features
Current Time: Tue Sep 16 11:27:33 EDT 2025
Powered by FUDForum. Page generated in 0.03214 seconds
