Home » Archived » M2M (model-to-model transformation) » [ATL] Copy Ecore Files.launch does not exist
[ATL] Copy Ecore Files.launch does not exist [message #69223] Wed, 12 December 2007 15:20 Go to next message
Hi all,
when I compile the ATL source code inside Eclipse, I get this error:
Errors during build.
Errors running builder 'Integrated External Tool Builder' on project
'org.eclipse.m2m.atl.engine'.
Launch configuration Copy Ecore Files at
....org.eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.engine/. externalToolBuilders/Copy
Ecore Files.launch does not exist.
What's wrong?
Matthias
Re: [ATL] Copy Ecore Files.launch does not exist [message #69324 is a reply to message #69223] Wed, 12 December 2007 18:19 Go to previous messageGo to next message
Hi Matthias,
.....org.eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.engine/ .externalToolBuilders/Copy
> What's wrong?
Depending on how your eclipse workspace is setup, .ecore files from the
src/ folder are copied or not to the bin/ folder.
Now that we understand that, the best solution is probably to make sure
the workspace is setup properly.
However, before we understood that, a solution had to be found. It
consisted in using an ant script to copy the .ecore files, with a
corresponding "external builder".
Note that I do find the "Copy Ecore Files.launch" file on the Eclipse CVS:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2m/org .eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.engine/.externa lToolBuilders/?root=Modeling_Project
You may have an incomplete checkout of the CVS.
In any case, now may be the time to switch to a simpler solution than
using this ant script :-).
Frédéric Jouault
Re: [ATL] Copy Ecore Files.launch does not exist [message #69607 is a reply to message #69324] Thu, 13 December 2007 13:13 Go to previous messageGo to next message
On 2007-12-13 00:19:03 +0100, Frédéric Jouault
Frédéric,
yes, I also find this file in my workspace. Maybe, the reason is that
the file name contains spaces? My machine is a MacBook Pro running
under Mac OS X.
If I understand you correctly, this external builder could be removed.
Who could do this and when?
Cheers
Matthias
Re: [ATL] Copy Ecore Files.launch does not exist [message #69745 is a reply to message #69607] Fri, 14 December 2007 16:32 Go to previous message
>> CVS:
> Hi
> Frédéric,
> the file name contains spaces? My machine is a MacBook Pro running under
> Mac OS X.
No problems on my MBPro, so that's not it.
> Cheers
> Matthias
I'm also ok with removing it. I put it there initially, b.t.w., so I can
remove it too. I don't have much time before 15th January, though, so a
workaround is in order:
- Select your project in the Package Explorer (or similar)
- Select "Project -> Properties" from the menu
- Select "Builders" in the list on the left
- Uncheck "Copy Ecore Files"
Dennis
Previous Topic:[ATL] NPE in content assist
Next Topic:[ATL]Problem running an ant file
Current Time: Thu Jul 24 22:13:27 EDT 2025
Powered by FUDForum. Page generated in 0.04232 seconds
