XML import in RCP [message #693043] |
Tue, 05 July 2011 12:57  |
Hi all,
I am new to Eclipse development. So I don't know whether it is proper to post this here. But here is the trouble I am facing,
I need to import data into an object and add the object to a list. I am using the following code,
SSAXParserFactory factory = SAXParserFactory.newInstance();
SAXParser saxParser = factory.newSAXParser();
DefaultHandler handler = new DefaultHandler() {
private InstallerFeature tempFeature;
private StringBuilder description;
public void startElement(String uri, String localName,
String qName, Attributes attributes)
throws SAXException {
if (qName.equalsIgnoreCase("FEATURE")) {
String test = attributes.getValue("id");
//System.out.println(test);
tempFeature.setPackageName("cdt");
tempFeature.setTitleName("cdt");
//System.out.println(tempFeature.getTitleName());
tempFeature.setVersonNumber(attributes.getValue("version"));
tempFeature.setImagePath(attributes.getValue("impath"));
} else if (qName.equalsIgnoreCase("DESCRIPTION")) {
description = new StringBuilder();
public void endElement(String uri, String localName,
String qName) throws SAXException {
features.add(tempFeature);
tempFeature = null;
tempFeature.setDescriptionContent(description.toString());
public void characters(char ch[], int start, int length)
if (description == null)
return;
description.append(String.valueOf(ch, start, length));
The object temp feature is defined as an InstallerFeature as below
public class InstallerFeature {
private String packageName;
private String titleName;
private String versonNumber;
private String imagePath;
private String descriptionContent;
public void setPackageName(String packageName) {
this.packageName = packageName;
public String getPackageName() {
return packageName;
public void setTitleName(String titleName) {
System.out.println("Code is being called here");
this.titleName = titleName;
public String getTitleName() {
return titleName;
public void setVersonNumber(String versonNumber) {
this.versonNumber = versonNumber;
public String getVersonNumber() {
return versonNumber;
public void setDescriptionContent(String descriptionContent) {
this.descriptionContent = descriptionContent;
public String getDescriptionContent() {
return descriptionContent;
public void setImagePath(String imagePath) {
this.imagePath = imagePath;
public String getImagePath() {
return imagePath;
When I run the code I am getting the following error
at ca.rokc.ide4edu.installer.Activator$1.startElement(Activator.java:120)
which points to the tempFeature.setPackageName() line in the importing code. I couldn't understand what to do. Please help
Re: XML import in RCP [message #693055 is a reply to message #693043] |
Tue, 05 July 2011 13:07   |
What code are you expecting will set tempFeature to a non-null value?
You've shown no code that does that...
> Hi all,
> tempFeature = null;
> return;
> length));
> return packageName;
> return titleName;
> return imagePath;
> at
Re: XML import in RCP [message #693169 is a reply to message #693055] |
Tue, 05 July 2011 19:59  |
HI Ed Merks,
Thanks for your reply. I understood what you have asked. I defined a constructor method in InstallerFeature and when need i called it as
tempFeature = new InstallerFeature();
That solved that NullPointerException.
Thanks for pointing me at the exact issue in the code
FUDForum. Page generated in 0.03848 seconds
