[Acceleo 3.1.0] Module file (.mtl) is not built into a .java file [message #691676] |
Fri, 01 July 2011 22:43  |
I switched from Helios to Indigo due to Papyrus compatibility issues. When I tried to build a new Acceleo module in this environment (Eclipse Indigo Release Build 20110615-0604 and Acceleo 3.1.0.v20110607-0602) I noticed that the .mtl file of my module was never built into a .java file as in the Helios version.
The option Project->Build Automatically has been activated all the time since installation. I changed the execution environment from J2SE-1.5 to JavaSE-1.6 in the "Properties for JRE System Library" dialog box and in the MANIFEST.MF file until no warning concerning to the incompatibility between J2SE-1.5 and JavaSE-1.6 appeard. But the .mtl file is still not built and the message "Selection does not contain a main type (@main annotation is missing in your main template)" keeps appearing when trying to run the template.
Does any of you have any suggestion to fix this problem?
Also, are Papyrus and Acceleo compatible? I am a newcomer and plan to use them both in my project.
Thanks a lot in advance. Kindest regards.
FUDForum. Page generated in 0.06010 seconds
