Home » Modeling » TMF (Xtext) » [xtext2] Scoping & Fragments
[xtext2] Scoping & Fragments [message #692798] Tue, 05 July 2011 05:10 Go to next message
Good morning community,
I have a question (What a surprise, I know).
I am facing some scoping problems including the thing where I only want that the elements in one file are only usable in the same file and not in all others to.
I know what I have to do to accomplish this task (ImportURIScopingFragment ...) but I also need some of the functionality of the ImportNamespacesScopingFragment.
So my first question is: I need to create my own fragment, which handles the things like I want it to, right?
I have tried this, but it didn't work. I created a class, which extends AbstractScopingFragment, and created an XPand file with the same name. But it don't work! It always shows me the following error:
 EvaluationException : No Definition 'AbstractScopingFragment::JavaScopeProvider(String) for org::eclipse::xtext::impl::GrammarImpl' found!
I found some hints, what this could all about but nothing really helped me... I also get this error when I just copy the codelines from ImportNamespacesScopingFragment in to the new fragment with the new name...
Am I on the right way? Is there a better solution? What am I doing wrong?
I just want the standard behavior without the ability to use a element from another file, which is not explicit included...
I am using XTEXT 2...
Thanks a lot for your input...
Re: [xtext2] Scoping & Fragments [message #692853 is a reply to message #692798] Tue, 05 July 2011 07:00 Go to previous messageGo to next message
you don't have to provide your own generator fragment. Both scoping
fragments simply define some bindings in the Guice module and create a
stub scope provider that you can implement. If you don't need to
implement your scoping semantics in many different languages, it's
simpler to just add the bindings manually.
The easiest way would be to override
ImportedNamespaceAwareLocalScopeProvider.getResourceScope(Resource,
EReference) and implement the desired behavior there.
Does that help?
Sebastian
> in all others to.
Re: [xtext2] Scoping & Fragments [message #693840 is a reply to message #692853] Thu, 07 July 2011 06:03 Go to previous messageGo to next message
Yes, thank you!
This was a solution. But I am wondering what have I made wrong, with my fragment... I don't really need this at the moment but I always like to understand things so can you (or someone else) point me to an example or something? Or is there something about fragment creation in the documentation what I have, overread?
(By the way: does anyone know how i could delete an account? (I created this thread with my old account...)
Re: [xtext2] Scoping & Fragments [message #695627 is a reply to message #693840] Tue, 12 July 2011 03:49 Go to previous message
Hi Nico,
I'm afraid there is no detailed documentation on writing own fragments
available. You could try to learn from simpler existing fragments such
as the JavaValidatorFragment.
Sebastian
On 07.07.11 12:03, Nico Lincke wrote:
> Yes, thank you!
Previous Topic:Multiple ANTLR versions using Xtext and third party library in a standalone application
Next Topic:Restricting cross-refference content assist
Current Time: Thu Jul 24 17:41:20 EDT 2025
Powered by FUDForum. Page generated in 0.05811 seconds
