Home » Modeling » OCL » using OCL from java
using OCL from java [message #692754] Tue, 05 July 2011 03:21 Go to next message
hello
i'm new with OCL in eclipse, so that coul be a noob question:
i tried to validate an uml model at runtime with java
i read the OCL Interpreter Tutorial and tried to use this for my aim
but i could not run the example, because i got a compile error in this line
OCL<?, EClassifier, ?, ?, ?, ?, ?, ?, ?, Constraint, EClass, EObject> ocl;
"the type OCL is not generic"
if i had understand the tutorial, i have to adapt the following line
ocl = OCL.newInstance(EcoreEnvironmentFactory.INSTANCE);
into something like this:
ocl = OCL.newInstance(UMLEnvironment.);
but there is no choice of INSTANCE like above
ever help is welcome
regards
stoehm
Re: using OCL from java [message #692771 is a reply to message #692754] Tue, 05 July 2011 03:54 Go to previous messageGo to next message
Stoehm,
are you sure you imported OCL from the correct package? Please note that there is more than one class named "OCL," each in a different package.
Best,
-- Axel
Re: using OCL from java [message #692795 is a reply to message #692771] Tue, 05 July 2011 04:57 Go to previous messageGo to next message
hi alex
thanks for your reply
thats it, i just took the false imports Embarrassed
but for me its still a problem, what is the analog call to
i want to have an UMLEnvironment but UMLEnvironmentFactory has no static fiel INSTANCE, i tried to call this:
ocl = OCL.newInstance(new UMLEnvironmentFactory().createEnvironment());
which causes again an compileerror
so maybe you can tell me the rigth call
best regards
stoehm
Re: using OCL from java [message #692820 is a reply to message #692795] Tue, 05 July 2011 05:56 Go to previous messageGo to next message
hi
ok i checked out the other problem with the resource, but for me there is still the problem, that i don't know what is the right call in case of UML since
is not working
any hint is welcome
best regards
[Updated on: Tue, 05 July 2011 08:45] by Moderator
Re: using OCL from java [message #693014 is a reply to message #692795] Tue, 05 July 2011 12:04 Go to previous messageGo to next message
HI
If you use F4, Open Type hierrachy you will discover four UML variants
of OCL.newInstance. The closest has a UMLEnvironmentFactory argument so
you could do OCL.newInstance(new UMLEnvironmentFactory()).
I'm afraid the UML documentation is thin.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=351214 raised.
We are not entirely clear whether the asymmetry between the UML and
Ecore binding is really necessary. It's a pain for us too.
Ed Willink
On 05/07/2011 09:57, stoehm wrote:
> hi alex
> thats it, i just took the false imports :blush: but for me its still
> best regards
> stoehm
Re: using OCL from java [message #693015 is a reply to message #692820] Tue, 05 July 2011 12:09 Go to previous messageGo to next message
The helper requires a Class argument, which you may obtain by naigating
your UML meta-model using UML's helper operations such as getOwnedType(c1);
Ed Willink
On 05/07/2011 10:56, stoehm wrote:
> hi
> trying to run the example, i have another question now
> is there an easy way to set the context of an OCLHelper object
> for example i have an example.uml which is located in any location,
> and this example.uml contains a package p1, with a class c1, now i
> want to set the context of an OCLHelper something like this
> helper.setContext(pathOfTheExampleUML.p1.c1)
> best regards
Re: using OCL from java [message #693352 is a reply to message #693015] Wed, 06 July 2011 05:53 Go to previous message
hello ed
thanks for your reply it helped me a lot
for now i have to read the APIs, i hope i get well along with it
best regards
stoehm
Previous Topic:Creating concrete model using threading
Next Topic:can ocl validate runtimeobjects against their classes
Current Time: Fri Jul 25 23:02:44 EDT 2025
Powered by FUDForum. Page generated in 0.05363 seconds
