Home » Eclipse Projects » Rich Client Platform (RCP) » Selection Service
Selection Service [message #692495] Mon, 04 July 2011 11:12 Go to next message
Hi all,
I subscribe to the selection service using:
getSite().getPage().addSelectionListener(String id ,ISelectionListener listener);
This works fine as long as my GMF editor is not already open when Eclipse opens. I did set a breakpoint and found out that the editor is registering. When closing and reopening the editor this is fixed. How can I get around this behaviour?
Ralph
(no subject) [message #692565 is a reply to message #692495] Mon, 04 July 2011 14:34 Go to previous messageGo to next message
Hi Ralph,
Set the listener on a spot that gets visited when the editor is opened. A
good place is the editors createPartControl method.
Wim
> Hi all,
listener);
this behaviour?
> Ralph
Re: (no subject) [message #692736 is a reply to message #692565] Tue, 05 July 2011 02:37 Go to previous message
adding the view as selection changed listener in the editor's plugin would violate the principle of loose coupeling. Is there no way to achieve this in the view's plugin? I have the code in the views createPart method. But somehow it must be related to Eclipse, because it only works when closing and opening the editor if it was open when eclipse started.
Ralph
Previous Topic:Declarative lightweight decorator
Next Topic:Unable to locate installable unit org.eclipse.ui.views
Current Time: Sat Aug 30 23:14:54 EDT 2025
Powered by FUDForum. Page generated in 0.06100 seconds
