Home » Archived » XML Schema Definition (XSD) » Loading Platform Resource URI based XML Schema
Loading Platform Resource URI based XML Schema [message #69251] Fri, 18 August 2006 10:07 Go to next message
I have a standalone application and I have an XML Schema file which is
built into the jar file in the package com.app.test. Unfortunately when I
run this code I get a problem with regards to path mapping not being setup
correctly. I do not know how I can set this up so that it may work. Can
anybody help me?
The error and the code I am using to load the XSDResourceImpl is detailed
below.
java.io.IOException: The path '/com/app/test/my.xsd' is unmapped
at
org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createP latformResourceInputStream(Ljava/lang/String;)Ljava/io/Input Stream;(URIConverterImpl.java:551)
at
org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createI nputStream(Lorg/eclipse/emf/common/util/URI;)Ljava/io/InputS tream;(URIConverterImpl.java:449)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Ljava/ util/Map;)V(ResourceImpl.java:892)
at
com.app.test.XmlSchemaLoading.load()V(OpenTwinsXmlSchemaLoad ing.java:49)
at
com.app.test.XmlSchemaLoading.<init>()V(OpenTwinsXmlSchemaLoading.java:29)
at
com.app.test.XmlSchemaLoading.main([Ljava/lang/String;)V(Ope nTwinsXmlSchemaLoading.java:110)
//Create a resource set to manage the different resources
ResourceSet resourceSet = new ResourceSetImpl();
//Register XSD resource factory
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put( "xsd",
new XSDResourceFactoryImpl());
//Create a resource for this file.
XSDResourceImpl xsdResource =
(XSDResourceImpl)resourceSet.createResource(URI.createPlatfo rmResourceURI( "com/app/test/my.xsd"));
try
xsdResource.load(null);
catch (IOException e)
e.printStackTrace(); // fails here.
XSDSchema xsdSchema = xsdResource.getSchema();
Re: Loading Platform Resource URI based XML Schema [message #69271 is a reply to message #69251] Fri, 18 August 2006 10:32 Go to previous messageGo to next message
Stuart,
You should get the URL within the jar that will access the resource.
I.e., java.lang.Class.getResource to determine the URL and use that
converted to a URI for loading the resource.
Stuart Stephen wrote:
> when I run this code I get a problem with regards to path mapping not
> being setup correctly. I do not know how I can set this up so that it
> may work. Can anybody help me?
> detailed below.
> at
> at
> at
> at
> at
> at
> try {
> catch (IOException e) {
Re: Loading Platform Resource URI based XML Schema [message #69410 is a reply to message #69271] Mon, 21 August 2006 03:55 Go to previous message
Thanks, I got this to work fine.
Re: Loading Platform Resource URI based XML Schema [message #598565 is a reply to message #69251] Fri, 18 August 2006 10:32 Go to previous message
Stuart,
> detailed below.
> at
> at
> at
> at
> at
> at
> try {
Re: Loading Platform Resource URI based XML Schema [message #598615 is a reply to message #69271] Mon, 21 August 2006 03:55 Go to previous message
Previous Topic:suggestion to use namespace prefix for nsPrefix in XSD2eCore mapping
Next Topic:How to annotate genmodel with a relative import location?
Current Time: Wed Jul 23 07:27:04 EDT 2025
Powered by FUDForum. Page generated in 0.07002 seconds
