Home » Modeling » TMF (Xtext) » appending text programmatically.
appending text programmatically. [message #692379] Mon, 04 July 2011 05:58 Go to next message
Hello there, Sorry for this trivial question, but I coudn't find a
method to append text to the xtext document programmatically.
How do I do this?
IXtextDocument doc = editor.getDocument();
doc.?
thx Christophe
Re: appending text programmatically. [message #692383 is a reply to message #692379] Mon, 04 July 2011 06:39 Go to previous messageGo to next message
doesn't doc.set(doc.get()+ whateverToAppend) work?
Alex
Re: appending text programmatically. [message #692392 is a reply to message #692383] Mon, 04 July 2011 06:54 Go to previous messageGo to next message
On 04-07-11 12:39, Alexander Nittka wrote:
> Alex
thanks, I actually resolved by this:
int len = doc.getLength();
try {
if( len == 0){
doc.set(toInsert);
}else{
doc.replace(len-1, toInsert.length(), toInsert);
} catch (BadLocationException e) {
e.printStackTrace();
Re: appending text programmatically. [message #692393 is a reply to message #692392] Mon, 04 July 2011 07:01 Go to previous messageGo to next message
Actuall this one is better, and doesn't replace the last char, and keeps
the cursor in place:
try {
if( len == 0){
doc.set(toInsert);
}else{
String lastChar = doc.get(len-1, 1);
doc.replace(len-1, toInsert.length(), lastChar + toInsert);
>> Hi,
>> Alex
> try {
> if( len == 0){
> doc.set(toInsert);
> }else{
Re: appending text programmatically. [message #692520 is a reply to message #692393] Mon, 04 July 2011 12:23 Go to previous messageGo to next message
In Xtext 1.0.x it was reccomended to do this using a unit of work; isn't
this necessary anymore?
> try {
> if( len == 0){
> doc.set(toInsert);
> }else{
>>> Hi,
>>> Alex
>> try {
>> if( len == 0){
>> doc.set(toInsert);
>> }else{
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: appending text programmatically. [message #692543 is a reply to message #692520] Mon, 04 July 2011 13:36 Go to previous messageGo to next message
changes to the model should still be done in a (modify) unit of work. The code responsible for applying quickfixes could serve as a guide. There you have a semantic version (modify the model) and a syntactic version (modify the document content).
Alex
Re: appending text programmatically. [message #692604 is a reply to message #692543] Mon, 04 July 2011 16:22 Go to previous message
On 04-07-11 19:36, Alexander Nittka wrote:
> Alex
OK, thx BTW the code earlier doesn't work, as I missread the .replace API.
This is better:
private void insertKeyPadText(String toInsert) {
try {
doc.replace(len, 0, toInsert);
In a Unit of Work of course :)
Cheers Christophe.
Previous Topic:Supertype from referenced ecore model
Next Topic:[Xtext] Processing Xtext Model
Current Time: Wed Jul 23 20:39:13 EDT 2025
Powered by FUDForum. Page generated in 0.05240 seconds
