Home » Modeling » TMF (Xtext) » Beginner grammar problem
Beginner grammar problem [message #692143] Sun, 03 July 2011 13:48 Go to next message
Hello EveryBody!
I have some problems with definition of mydsl grammar
I have several Lists<String> which are Writers, Books PageNumber, Isb respectively in my ProposalProvider class
in myDsl I will create a text line which is called NonEmptyline which consists of the lists of Writers, Books PageNumber, Isbn respectively
for example: in my DSL, each line has to be just like this
Stefen_King:Full_Dark_No_Stars:789:1234567
each element will be called from a different List by content assist. Here my code is below, when i run as .MWE2 i get errors
Librarymodel:
	(elements+=NonEmptyline)*;
NonEmptyline:
	Writers':' Books ':'PageNumber ':' IsbnNumber
Writers:
	 name=WriterName ':';
	WriterName hidden(): ID (WS ID)* ;
Books:
	name=BookName ':'
	BookName hidden (): ID (WS ID)* ;
PageNumber:
	name=Page ':'
	Page hidden (): ID (WS ID)* ;
IsbnNumber:
	name=Isbn ':'
	Isbn hidden (): ID (WS ID)* ;
I look forward to hear your solutions
Sincerely
[Updated on: Sun, 03 July 2011 13:49] by Moderator
Re: Beginner grammar problem [message #692147 is a reply to message #692143] Sun, 03 July 2011 13:59 Go to previous messageGo to next message
there a lots of complicated stuff in your grammar. its way to complicated. what about something like
in parser rules you should always assign stuff.
each rule must be closed with a semicolon.
Librarymodel:
NonEmptyline:
	writer=Words ':' book=Words ':'pageNumber=INT ':' isbn=INT
Words hidden (): ID (WS ID)* ;
~Christian
[Updated on: Sun, 03 July 2011 14:00] by Moderator
Re: Beginner grammar problem [message #692155 is a reply to message #692147] Sun, 03 July 2011 14:35 Go to previous messageGo to next message
Thanks you so much again, this works,
I have one more question if when Stefen_King has been chosen as a writer from content assist, how can i display just Stefen_King 's books intstead of all books?
Best
Re: Beginner grammar problem [message #692157 is a reply to message #692155] Sun, 03 July 2011 14:39 Go to previous messageGo to next message
what about a filtered content assist for the books? just query the Context (downcasting EObject model to NonEmptyline andf ask it for the writer)
but what i do not understand is: if you have all the data why to do the modeling stuff at all???
~Christian
~Christian
Re: Beginner grammar problem [message #692158 is a reply to message #692157] Sun, 03 July 2011 14:43 Go to previous messageGo to next message
well i have an existing language for my data, we have used this language on text file for a long time
Now we decided to have a simple editor which is capable for coloring and error checking and content assist
Re: Beginner grammar problem [message #692159 is a reply to message #692158] Sun, 03 July 2011 14:46 Go to previous messageGo to next message
just to make this clear: you have files/models for the master data as well? why don't you use a dsl for these to and use cross refs for the Librarymodel?
~Christian
Re: Beginner grammar problem [message #692160 is a reply to message #692159] Sun, 03 July 2011 15:01 Go to previous messageGo to next message
Hi again
Thanks again and again for advance suggestion, this is explicitly what i need for my librarymodel, However I need to study on it Smile
Re: Beginner grammar problem [message #692391 is a reply to message #692160] Mon, 04 July 2011 07:06 Go to previous messageGo to next message
hello Christian
can you give me any sample for this reference linking based on my Librarymodel ,
Re: Beginner grammar problem [message #692396 is a reply to message #692391] Mon, 04 July 2011 07:28 Go to previous messageGo to next message
since i do not know you masterdata dsl: no
~Christian
Re: Beginner grammar problem [message #692405 is a reply to message #692396] Mon, 04 July 2011 07:47 Go to previous messageGo to next message
Librarymodel:
	(elements+=CrossReference)*;
CrossReference:
	referencedObjct=[NonEmpityLine];
NonEmptyline:
is this right as grammar?
~ProposalProvider extends Abstract~..~ProposalProvider implements ILinkingService {
ArrayList<String> writers = new ArrayList<String>();
writers.add("writer1");
writers.add("writer2");
writers.add("writer3");
	public void complete_writers(EObject model, RuleCall ruleCall,
			ContentAssistContext context, ICompletionProposalAcceptor acceptor) {
		for(String writer: writers){
			acceptor.accept(createCompletionProposal(writer,context));
		// TODO Auto-generated method stub
		super.complete_LogItem(model, ruleCall, context, acceptor);
// Actually, I dont know how to context this with writer
	public List<EObject> getLinkedObjects(EObject context,
			EReference reference, INode node) throws IllegalNodeException {
		return null;
}//class end
[Updated on: Mon, 04 July 2011 08:32] by Moderator
Re: Beginner grammar problem [message #692427 is a reply to message #692405] Mon, 04 July 2011 08:20 Go to previous messageGo to next message
No,
if you want to crossref something you need the something somewhere. where is that in your case? where are the "Books" master data defined?
~Christian
Re: Beginner grammar problem [message #692433 is a reply to message #692427] Mon, 04 July 2011 08:33 Go to previous messageGo to next message
All i have above , in the class
some more array such as
ArrayList<String>writer1sbooks;
writer1sbooks== new ArrayList<String>();
writer1sbooks.add.....
[Updated on: Mon, 04 July 2011 08:36] by Moderator
Re: Beginner grammar problem [message #692438 is a reply to message #692433] Mon, 04 July 2011 08:41 Go to previous messageGo to next message
then it is a missunderstanding that you can use references
~CVhr
Re: Beginner grammar problem [message #692440 is a reply to message #692438] Mon, 04 July 2011 08:45 Go to previous messageGo to next message
Thank anyway for you help Wink
I just wonder when I typed
writer1:"HERE!!"
how can I display in the content assit window the writer1s book as proposal, do u know any otherway?
Re: Beginner grammar problem [message #692442 is a reply to message #692440] Mon, 04 July 2011 08:47 Go to previous messageGo to next message
As i said before, customize content assist. by downcasting EObject model and check the writers name. ~Christian
Re: Beginner grammar problem [message #692760 is a reply to message #692442] Tue, 05 July 2011 03:32 Go to previous messageGo to next message
Hi Christian, Please can you explain what you mean with by downcasting EObject model based on my Proposal provider?
Re: Beginner grammar problem [message #692789 is a reply to message #692760] Tue, 05 July 2011 04:33 Go to previous message
see you other post
Previous Topic:pdf of xtext 2 documentation
Next Topic:Inject a different StaticMethodsFeatureForTypeProvider
Current Time: Tue Nov 04 03:19:15 EST 2025
Powered by FUDForum. Page generated in 0.05489 seconds
