Home » Eclipse Projects » Rich Client Platform (RCP) » Unable to locate installable unit org.eclipse.ui.views
Unable to locate installable unit org.eclipse.ui.views [message #692114] Sun, 03 July 2011 11:15 Go to next message
I can't make my target definition find org.eclipse.ui.views.
In my target locations I have:
- Software Site org.eclipse.rcp
- Directory with delta.pack
One of my plugins has:
import org.eclipse.ui.views.properties.IPropertySource
So I have to declare a dependency on org.eclipse.ui.views.
That's where the problems begin.
If I try the usual plugin.xml/Dependencies/Add... procedure, the Plug-in
Selection dialog can't find org.eclipse.ui.views.
If I then try the quick-fix suggestion, it offers me to Search
Repositories for 'org.eclipse.ui.views.properties', opening a dialog
titled "Add Artifact to Target Platform".
I see some network activity for a while, but no matching items are found.
Same result if I search for artifact org.eclipse.ui.views.
I probably have to add some other target location, but I have no clue.
I'm running indigo.
Any help?
Carlo
Re: Unable to locate installable unit org.eclipse.ui.views [message #693074 is a reply to message #692114] Tue, 05 July 2011 14:09 Go to previous message
On 7/3/2011 5:15 PM, Carlo Salinari wrote:
> I'm running indigo.
Solved.
I had to add Software Site:
http://download.eclipse.org/releases/indigo
features:
Eclipse RCP
Eclipse Platform (this is the one containing org.eclipse.ui.views)
Previous Topic:Selection Service
Next Topic:XML import in RCP
Current Time: Sun Aug 31 14:54:28 EDT 2025
Powered by FUDForum. Page generated in 0.02581 seconds
