Re: Eclipse (3.7) indigo no repository found errors [message #761781 is a reply to message #692038] |
Tue, 06 December 2011 22:17  |
I ran eclipse in debug mode and I have the following log. I don't see anything flagged as an error or problem.
user@V6133CL:~$ eclipse -debug
Start VM: -Xms40m
-Xmx384m
-Dorg.eclipse.equinox.p2.reconciler.dropins.directory=/usr/share/eclipse/dropins
-XX:MaxPermSize=256m
-Djava.class.path=/usr/lib/eclipse//plugins/org.eclipse.equinox.launcher_1.2.0.dist.jar
-os linux
-ws gtk
-arch x86
-showsplash /usr/lib/eclipse//plugins/org.eclipse.platform_3.7.0.dist/splash.bmp
-launcher /usr/lib/eclipse/eclipse
-name Eclipse
--launcher.library /usr/lib/eclipse//plugins/org.eclipse.equinox.launcher.gtk.linux.x86_1.1.100.dist/eclipse_1407.so
-startup /usr/lib/eclipse//plugins/org.eclipse.equinox.launcher_1.2.0.dist.jar
--launcher.overrideVmargs
-debug
-vm /usr/lib/jvm/java-6-openjdk/jre/bin/../lib/i386/client/libjvm.so
-vmargs
-Xms40m
-Xmx384m
Install location:
file:/usr/lib/eclipse/
Configuration file:
file:/usr/lib/eclipse/configuration/config.ini loaded
Configuration location:
file:/home/user/.eclipse/org.eclipse.platform_3.7.0_155965261/configuration/
Configuration file:
file:/home/user/.eclipse/org.eclipse.platform_3.7.0_155965261/configuration/config.ini loaded
Shared configuration location:
Framework located:
file:/usr/lib/eclipse/plugins/org.eclipse.osgi_3.7.0.dist.jar
Framework classpath:
Splash location:
Debug options:
file:/home/user/.options not found
Time to load bundles: 8
Starting application: 1290
Application Started: 64539
user@V6133CL:~$
FUDForum. Page generated in 0.51608 seconds
