Home » Modeling » TMF (Xtext) » [XPAND] complexe SEPARATOR use
[XPAND] complexe SEPARATOR use [message #691530] Fri, 01 July 2011 12:44 Go to next message
Hi everyone.
I'm Feriaman, i use XPand in a XText project, it is really impressive. I carefully readed the manual, but i cannot find a way to do something that should be pretty easy.
First question :
I'd like to make a rule like this :
«EXPAND rule FOREACH ABasketOfTomatoesAndCuncumbers SEPARATOR ','»
with :
«DEFINE rule FOR Tomato»«ENDDEFINE»
«DEFINE rule FOR Cuncumber»green«ENDDEFINE»
And I'd like to obtain this :
(Tomato,Cuncumber,Tomato,Tomato,Cuncumber) ---> green,green
But of course i obtain :
(Tomato,Cuncumber,Tomato,Tomato,Cuncumber) ---> ,green,,,green
Second question :
In fact i'd like to output a keword before my enumeration, something like this :
=>green,green
that could be achieve by writing the rule like this :
=>«EXPAND rule FOREACH ABasketOfTomatoesAndCuncumbers SEPARATOR ','»
(Tomato) ---> "" (nothing)
And of course i obtain this :
(Tomato) ---> "=>"
Thanks to every reader.
Thanks to every answerer.
Re: [XPAND] complexe SEPARATOR use [message #691536 is a reply to message #691530] Fri, 01 July 2011 12:59 Go to previous messageGo to next message
I just saw i may be in the wrong section... the XPand section may have been more suitable ?
Sorry if i am wrong.
Re: [XPAND] complexe SEPARATOR use [message #691545 is a reply to message #691530] Fri, 01 July 2011 13:24 Go to previous messageGo to next message
Hi, why don't you filter the lists you pass to the foreach e.g. with
a typeselect. Regards Christian
Re: [XPAND] complexe SEPARATOR use [message #691549 is a reply to message #691545] Fri, 01 July 2011 13:39 Go to previous message
Hi Christian
Thanks alot you solve my problem and made me realize i could use the "Special Collection operations" inside the ".xpt" file ... that i haven't realized yet.
Thanks again.
«IF ABasketOfTomatoesAndCuncumbers.typeSelect(Cuncumber).select(c | c.diametre > 4) != {}-»
     «EXPAND rule FOREACH ABasketOfTomatoesAndCuncumbers.typeSelect(Cuncumber).select(c | c.diametre > 4) SEPARATOR ','-»
«ENDIF-»
[Updated on: Fri, 01 July 2011 13:48] by Moderator
Previous Topic:Syntax highlight for Enums
Next Topic:Getting an Editor instance/ Resource for a Validator
Current Time: Mon Jul 21 05:59:18 EDT 2025
Powered by FUDForum. Page generated in 0.04748 seconds
