Home » Modeling » OCL » Unable to perform OCL validation outside eclipse
Unable to perform OCL validation outside eclipse [message #691471] Fri, 01 July 2011 10:16 Go to next message
I'm trying to create a class that is capable of loading a model (conforming to a specific metamodel) and an OCL document. The purpose of the class is to validate the ocl constraints (from the OCL document) on the model.
The class is based on the CompleteOCLEObjectValidator as shown in this presentation: http://www.slideshare.net/EdWillink/enriching-withocl
Note that in my case, I'm not using some kind of an XText based editor. Therefore, I think that I can not completely copy the example as found in the presentation.
However, my code looks like this:
public class MyValidator extends CompleteOCLEObjectValidator {
	public MyValidator(EPackage ePackage, URI oclURI) {
		super(ePackage, oclURI);
		ResourceSet resourceSet = new ResourceSetImpl();
		Resource model;
		URI oclURI = URI.createFileURI(args[0]);
		URI modelURI = URI.createFileURI(args[1]);
		EXTLibraryPackage.eINSTANCE.eClass();
		// register XMI resource factory for all other extensions
		Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put(
				Resource.Factory.Registry.DEFAULT_EXTENSION,
				new XMIResourceFactoryImpl());
		model = resourceSet.getResource(modelURI, true);
		EObject rootObject = model.getContents().get(0);
		MyValidator myValidator = new MyValidator(EXTLibraryPackage.eINSTANCE,
				oclURI);
		myValidator.validate(rootObject, null,null);
However, when I try to run it (started as a run configuration from eclipse), I get the following message:
Exception in thread "main" java.lang.ExceptionInInitializerError
	at org.eclipse.ocl.examples.pivot.ecore.Ecore2Pivot$Factory.<init>(Ecore2Pivot.java:72)
	at org.eclipse.ocl.examples.pivot.ecore.Ecore2Pivot$Factory.<init>(Ecore2Pivot.java:71)
	at org.eclipse.ocl.examples.pivot.utilities.TypeManager.<clinit>(TypeManager.java:200)
I think I'm doing something wrong regarding the initialization. Any ideas?
Greetings,
Wilbert.
Re: Unable to perform OCL validation outside eclipse [message #691559 is a reply to message #691471] Fri, 01 July 2011 13:55 Go to previous messageGo to next message
Have you not done any of the initialization in
http://help.eclipse.org/indigo/topic/org.eclipse.ocl.doc/help/Standalone.html
and none of the initialization omitted.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=350955 raised to improve
the API and documentation.
The following has the required init and works for me.
public class MyValidator {
public static void main(String[] args) throws ParserException {
// Initialize OCL
CompleteOCLStandaloneSetup.doSetup();
OCLstdlib.install();
// Register path in *.ocl for use standalone
// FIXME (Bug 350955) it should be possible to do this in a
local ResourceSet
EPackage.Registry.INSTANCE.put("platform:/resource/org.eclipse.emf.examples.library/model/extlibrary.ecore",
EXTLibraryPackage.eINSTANCE);
CompleteOCLEObjectValidator myValidator = new
CompleteOCLEObjectValidator(EXTLibraryPackage.eINSTANCE, oclURI);
Resource model = resourceSet.getResource(modelURI, true);
BasicDiagnostic diagnostics = new BasicDiagnostic();
myValidator.validate(rootObject, diagnostics, null);
// FIXME Should install a Composite EObjectValidator to do both OCL and
EMF validation
// EValidator.Registry.INSTANCE.put(EXTLibraryPackage.eINSTANCE,
myValidator);
// Diagnostic diagnostics =
Diagnostician.INSTANCE.validate(rootObject);
// System.out.println(diagnostics.getMessage());
for (Object object : diagnostics.getChildren()) {
System.out.println(object);
Ed Willink
On 01/07/2011 16:16, Wilbert Alberts wrote:
> public static void main(String[] args) {
> Resource model;
> oclURI);
> at
> at
> at
> ideas?
> Greetings,
> Wilbert.
Re: Unable to perform OCL validation outside eclipse [message #692305 is a reply to message #691559] Mon, 04 July 2011 03:32 Go to previous messageGo to next message
Hi Ed,
Thanks for your reply. The code is running now. However, I get an error which I don't quite understand.
The ocl file containing the constraints I'm trying to validate looks like:
import 'platform:/resource/org.eclipse.emf.examples.library/model/extlibrary.ecore'
package extlibrary
context Library
inv NameShouldBeWilbert: self.name = 'Wilbert'
endpackage
Running the validator leads to the following message:
0    [main] ERROR idation.CompleteOCLEObjectValidator  - Failed to load 'Library.ocl
Unresolved import 'platform:/resource/org.eclipse.emf.examples.library/model/extlibrary.ecore' : resolve against non-hierarchical or relative base
Unresolved Package 'extlibrary'
Unresolved Type 'Library'
Diagnosis of org.eclipse.emf.examples.extlibrary.impl.LibraryImpl@e1f305{Library.xmi#/}
The editor inside eclipse signals no errors in the OCL file, so it recognizes the extlibrary.ecore. I even tried to deploy the extlibrary project as a plugin and replaced the platform based URI by a http uri (as given by the properties of teh extlibrary package in the ecore file. Unfortunately that doesn't help.
Another suggestion would be helpful,
Greetings,
Wilbert.
Re: Unable to perform OCL validation outside eclipse [message #692344 is a reply to message #692305] Mon, 04 July 2011 05:00 Go to previous messageGo to next message
It cannot both be running and getting an error.
Please check that you are using my code; the initialization order is
important.
Please post examples rather than indications of your problems.
Ed Willink
Re: Unable to perform OCL validation outside eclipse [message #692366 is a reply to message #692344] Mon, 04 July 2011 05:58 Go to previous messageGo to next message
Hi Ed,
Indeed, running and giving an error sounds contradictory.
OK, the code:
		// Initialize OCL
		// FIXME (Bug 350955) it should be possible to do this in a local
		// ResourceSet
		CompleteOCLEObjectValidator myValidator = new CompleteOCLEObjectValidator(
				myValidator);
		Diagnostic diagnostics = Diagnostician.INSTANCE.validate(rootObject);
As I don't understand the 'FIXME' comment you added, it might be that I was expected to modify something there.
The OCL file containing the constraints:
package extlibrary
context Library
endpackage
The error message:
Diagnosis of org.eclipse.emf.examples.extlibrary.impl.LibraryImpl@232697{Library.xmi#/}
I checked that the 'unresolved import' URI refers to the one given in the OCL file.
Hope this helps.
Greetings,
Wilbert.
Re: Unable to perform OCL validation outside eclipse [message #692537 is a reply to message #692366] Mon, 04 July 2011 12:50 Go to previous messageGo to next message
You did'n't provide your command line/launch config or XMI file.
It looks as if you haven't provided a full absolute path to Library.ocl
on your args. Your processing certainly has nothing to apply default paths.
Ed Willink
On 04/07/2011 10:58, Wilbert Alberts wrote:
> Hi Ed,
> OK, the code:
> // Initialize OCL
> // ResourceSet
> myValidator);
> import
> package extlibrary
> context Library
> endpackage
> The error message:
> load 'Library.ocl
> Unresolved import
> Diagnosis of
> mailto:org.eclipse.emf.examples.extlibrary.impl.LibraryImpl@232697{Library.xmi#/}
> the OCL file.
> Hope this helps.
> Greetings,
> Wilbert.
Re: Unable to perform OCL validation outside eclipse [message #692747 is a reply to message #692537] Tue, 05 July 2011 03:08 Go to previous messageGo to next message
Hi Ed,
GREAT!
I modified the command line arguments (in the launch configuration) such that they have an absolute path. Now it works!
The only thing I would like to know now is: why? Note that when I changed the import 'platform:/resource/or...del/extlibrary.ecore' line, I saw the change reflected in the error message so I had the impression that the OCL file had been read (although I didn't understand what was meant with: 'resolve against non-hierarchical or relative base'). But clearly your suggestion helped.
I appreciate your help and would even be more thankful in case you could point me to some clue to the 'why' part.
Thanks!
Wilbert
Re: Unable to perform OCL validation outside eclipse [message #693016 is a reply to message #692747] Tue, 05 July 2011 12:13 Go to previous messageGo to next message
which line? there's at least: one in the *.ocl and one in the *.java
what error message? from the editor or from running the program?
Ed Willink
Re: Unable to perform OCL validation outside eclipse [message #694202 is a reply to message #693016] Fri, 08 July 2011 01:22 Go to previous messageGo to next message
I meant the *.ocl line.
The error from running the program:
The line starting with Unresolved import changed according to the content of the ocl file. So putting import foo.ecore in the ocl file lead to Unresolved import 'foo.ecore'
My apologies for being so ambiguous.
Greetings,
Wilbert
Re: Unable to perform OCL validation outside eclipse [message #694397 is a reply to message #692747] Fri, 08 July 2011 09:34 Go to previous message
The "import
'platform:/resource/org.eclipse.emf.examples.library/model/extlibrary.ecore'"
within the *.ocl can be resolved by the editor using Eclipse plugin
registrations.
The corresponding standalone functionality requires manual assistance to
make the 'platform:' scheme work. This is what
local ResourceSet
(together with my note to myself to improve the API).
If you change the import you will need to ensure that the standalone
functionality is able to resolve the URI used in the *.ocl file.
Ed Willink
On 05/07/2011 08:08, Wilbert Alberts wrote:
> Hi Ed,
> GREAT!
> Thanks!
> Wilbert
Previous Topic:can ocl validate runtimeobjects against their classes
Next Topic:Validating superclass constraints in OCL
Current Time: Sun Jul 27 04:01:19 EDT 2025
Powered by FUDForum. Page generated in 0.04577 seconds
