Weird fragment deployment behaviour [message #691311] |
Fri, 01 July 2011 04:04  |
Hi everyone. I'm trying to get Hibernate (bundles from the Springsource repository) running in Virgo 3.0.0.M5 and encountered problems with HQL-Queries. I figured out it's a problem of antlr not having access to some Hibernate classes and I tried to use the solution described here: Using a fragment to "inject" the import of org.hibernate.hql.ast into antlr.
My fragment bundle is only containing the following MANIFEST.MF:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Fragment-Host: com.springsource.antlr;bundle-version="[2.7.6,3.0.0)"
Bundle-SymbolicName: my.project.hibernate.antlrHelpFragment
Bundle-Name: AntlrHelpFragment
Bundle-Description: Classpath-Helper for HQL queries
Bundle-Version: 1.0.0
Import-Package: org.hibernate.hql.ast
When deploying the following output occurs:
[2011-07-01 09:44:54.937] TCP Connection(2)-127.0.0.1 <DE0000I> Installing bundle 'my.project.hibernate.antlrHelpFragment' version '1.0.0'.
[2011-07-01 09:44:55.563] fs-watcher <HD0001I> Hot deployer processing 'INITIAL' event for file 'org.eclipse.virgo.apps.admin-3.0.0.M05.plan'.
[2011-07-01 09:44:57.048] TCP Connection(2)-127.0.0.1 <ME0003I> Dump 'serviceability\dump\2011-07-01-09-44-944' generated
[2011-07-01 09:44:57.055] TCP Connection(2)-127.0.0.1 <DE0002E> Installation of bundle 'my.project.hibernate.antlrHelpFragment' version '1.0.0' failed. org.eclipse.virgo.kernel.osgi.framework.UnableToSatisfyBundleDependenciesException: Unable to satisfy dependencies of bundle 'my.project.hibernate.antlrHelpFragment' at version '1.0.0': Cannot resolve: my.project.hibernate.antlrHelpFragment
at org.eclipse.virgo.kernel.install.pipeline.stage.resolve.internal.QuasiResolveStage.process(QuasiResolveStage.java:45)
at org.eclipse.virgo.kernel.install.pipeline.internal.StandardPipeline.doProcessTree(StandardPipeline.java:62)
at org.eclipse.virgo.kernel.install.pipeline.internal.CompensatingPipeline.doProcessTree(CompensatingPipeline.java:72)
at org.eclipse.virgo.kernel.install.pipeline.stage.AbstractPipelineStage.process(AbstractPipelineStage.java:41)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.driveInstallPipeline(PipelinedApplicationDeployer.java:285)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.doInstall(PipelinedApplicationDeployer.java:164)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.install(PipelinedApplicationDeployer.java:136)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.deploy(PipelinedApplicationDeployer.java:203)
at org.eclipse.virgo.kernel.deployer.management.StandardDeployer.deploy(StandardDeployer.java:52)
at com.sun.jmx.mbeanserver.ConvertingMethod.invokeWithOpenReturn(Unknown Source)
at com.sun.jmx.mbeanserver.MXBeanIntrospector.invokeM2(Unknown Source)
at com.sun.jmx.mbeanserver.MBeanIntrospector.invokeM(Unknown Source)
at com.sun.jmx.mbeanserver.PerInterface.invoke(Unknown Source)
at com.sun.jmx.mbeanserver.MBeanSupport.invoke(Unknown Source)
at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.invoke(Unknown Source)
at com.sun.jmx.mbeanserver.JmxMBeanServer.invoke(Unknown Source)
at javax.management.remote.rmi.RMIConnectionImpl.doOperation(Unknown Source)
at javax.management.remote.rmi.RMIConnectionImpl.access$200(Unknown Source)
at javax.management.remote.rmi.RMIConnectionImpl$PrivilegedOperation.run(Unknown Source)
at javax.management.remote.rmi.RMIConnectionImpl.doPrivilegedOperation(Unknown Source)
at javax.management.remote.rmi.RMIConnectionImpl.invoke(Unknown Source)
at sun.rmi.server.UnicastServerRef.dispatch(Unknown Source)
at sun.rmi.transport.Transport$1.run(Unknown Source)
at sun.rmi.transport.Transport.serviceCall(Unknown Source)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(Unknown Source)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(Unknown Source)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
[2011-07-01 09:44:57.057] TCP Connection(2)-127.0.0.1 <DE0003E> Install failed for bundle 'my.project.hibernate.antlrHelpFragment' version '1.0.0'.
[2011-07-01 09:44:57.059] TCP Connection(2)-127.0.0.1 <DE0500E> Unable to install application from URI 'file:/C:/Data/src/virgo-tomcat-server-3.0.0.M05/stage/my.project.hibernate.antlrHelpFragment.jar'. Cannot satisfy constraints for bundle 'my.project.hibernate.antlrHelpFragment' version '1.0.0'. Cannot resolve: my.project.hibernate.antlrHelpFragment
From this output I would guess, the deployment failed? (Because the fragment looks for a dependency to itself?) But nevertheless, the fragment shows up in the admin console and HQL queries are working as expected.
Am I missing something in my MANIFEST.MF or is this a bug of Virgo?
FUDForum. Page generated in 0.34652 seconds
