Home » Eclipse Projects » Eclipse Platform » Custom javadoc
Custom javadoc [message #691375] Fri, 01 July 2011 06:31 Go to next message
Greetings.
I've been extensively modifying jdt.core plugin, including the grammar itself. It has come to a point where I need to be able to present the users with an ability to use javadoc tool. The trouble is that javadoc is an outside tool that is oblivious to the newly introduced grammar changes, and the whole process of generating the documentation fails. Such a thing happens due to the fact that javadoc uses the standard javac compiler instead of the modified grammar inside jdt.core. The question is, can you recommend an open-source javadoc-like plugin for eclipse, and is there even such a thing?
Thank you, good people.
Best,
Milan
Re: Custom javadoc [message #695323 is a reply to message #691375] Mon, 11 July 2011 09:38 Go to previous messageGo to next message
On 01.07.2011 12:31, Milan Vidakovic wrote:
> Greetings.
I don't know of any but maybe you can write your own doclet that then
interacts with JDT Core.
Dani
> Best,
> Milan
Re: Custom javadoc [message #695866 is a reply to message #691375] Tue, 12 July 2011 13:10 Go to previous messageGo to next message
>>Dani
Hi Dani,
I thought javadoc doclets only helped with the "look&feel" portion of the javadoc experience. When standard javadoc bumps into a new custom keyword, or an operator overloading feature, it pops-out a compile error. If a simple doclet could make javadoc look past that, it would be a life-saver to me. Could you, please, elaborate on your proposition just a little bit more, so I could start looking into it, since I've been pondering a thought of making a javadoc plugin for eclipse from scratch.
Thank you
Milan
Re: Custom javadoc [message #696033 is a reply to message #695866] Wed, 13 July 2011 02:26 Go to previous message
>>> then interacts with JDT Core.
>>> Dani
> Hi Dani,
It was just a hint. I would also have to dig deeper to give more details.
Dani
> Thank you
> Milan
Previous Topic:(no subject)
Next Topic:CompareUIPlugin throws a NullPointerException
Current Time: Wed Jul 23 15:36:59 EDT 2025
Powered by FUDForum. Page generated in 0.03928 seconds
