Home » Modeling » TMF (Xtext) » [Xtext] Problems with imported grammars and ecore models
[Xtext] Problems with imported grammars and ecore models [message #691196] Thu, 30 June 2011 18:52 Go to next message
Originally posted by:
I'm trying to transition from generated to imported model (because I
need to tweak the model) and experience problems with package URIs, I think.
In the grammar I extend Xbase and then import my own model, as follows:
grammar org.hal.ecoretypes.Test1 with org.eclipse.xtext.xbase.Xbase
import "platform:/plugin/no.hal.ecoretypes.core/model/process.ecore"
In process.ecore, I refer to EClasses defined in both Xbase and
JavaTypes, and use the http://.../ URIs for referencing the
corresponding packages.
In the model, I have rules like the following:
Rule : outPort = [Port] ':=' expression = XExpression ('when' guard =
XExpression)?
I get an error marker stating that "Cannot find compatible feature
expression in sealed EClass Rule from imported package
platform:/plugin/no.hal.ecoretypes.core/model/process.ecore. The
existing reference 'expression' has an incompatible type 'XExpression'."
I get the feeling there are two XEpression classes, one referenced by
process.ecore and one accessible through the extended grammar
org.eclipse.xtext.xbase.Xbase. Hence, they seem incompatible although
they should be the same. I notice that in the generated package (before
migrating to importing it), references to Xbase used a relative URI with
lots of leading ../ segments. But I've always avoided using such in my
own models, prefering the "official" http-schemed URI.
So, what should I do?
Hallvard
Re: [Xtext] Problems with imported grammars and ecore models [message #691379 is a reply to message #691196] Fri, 01 July 2011 06:46 Go to previous messageGo to next message
Now I've managed to satisfy the xtext editor, so it no longer gives the
error marker for the XExpression type. Here's the relevant part of the
grammar:
grammar no.hal.ecoretypes.Process with org.eclipse.xtext.xbase.Xbase
import "http://www.eclipse.org/xtext/xbase/Xbase" as xbase
import "http://www.eclipse.org/xtext/common/JavaVMTypes" as types
import "platform:/resource/no.hal.ecoretypes.xtext/model/process.ecore"
Rule: {Rule}
XExpression)? ';'
(it seems to work whether or not I import xbase and javavmtypes)
However, now I get the following error when running the mwe2 file:
Caused by: java.lang.IllegalStateException: Problem parsing
'classpath:/no/hal/ecoretypes/Process.xtext':[TransformationDiagnostic:
null:29 Cannot find type for ' XExpression'. (ErrorCode:
NoSuchTypeAvailable), TransformationDiagnostic: null:29 Cannot find type
for ' XExpression'. (ErrorCode: NoSuchTypeAvailable),
TransformationDiagnostic: null:33 Cannot find type for '
JvmParameterizedTypeReference'. (ErrorCode: NoSuchTypeAvailable),
TransformationDiagnostic: null:37 Cannot find type for '
TransformationDiagnostic: null:43 Cannot find type for '
JvmTypeReference'. (ErrorCode: NoSuchTypeAvailable),
TransformationDiagnostic: null:50 Cannot find type for '
TransformationDiagnostic: null:53 Cannot find type for '
JvmTypeReference'. (ErrorCode: NoSuchTypeAvailable)]
at
org.eclipse.xtext.generator.LanguageConfig.setUri(LanguageConfig.java:131)
... 43 more
It looks as though mwe2 parses the xtext file without XExpression in its
classpath? But I have the following in the mwe2 file:
bean = StandaloneSetup {
platformUri = "${runtimeProject}/.."
registerGeneratedEPackage = "org.eclipse.xtext.xbase.XbasePackage"
registerGeneratedEPackage = "org.eclipse.xtext.common.types.TypesPackage"
registerGeneratedEPackage = "no.hal.ecoretypes.process.ProcessPackage"
Hallvard
On 01.07.11 00.52, Hallvard Trætteberg wrote:
> think.
> XExpression)?
> Hallvard
Re: [Xtext] Problems with imported grammars and ecore models [message #691406 is a reply to message #691379] Fri, 01 July 2011 07:51 Go to previous messageGo to next message
The following mwe2 fragment worked:
scanClassPath = true
// registerGeneratedEPackage = "org.eclipse.xtext.xbase.XbasePackage"
// registerGeneratedEPackage = "no.hal.ecoretypes.process.ProcessPackage"
registerGenModelFile =
"platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel"
"platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel"
I.e. I load the genmodels instead of the packages. I'm sure this is
related to how I use URIs to refer to the xbase and jvmtypes packages,
but I don't understand why?
An explanation would be great!
Hallvard
On 01.07.11 12.46, Hallvard Trætteberg wrote:
> grammar:
> Rule: {Rule}
> XExpression)? ';'
> at
> ... 43 more
> Hallvard
>> Hi,
>> think.
>> XExpression)?
>> Hallvard
Re: [Xtext] Problems with imported grammars and ecore models [message #692612 is a reply to message #691406] Mon, 04 July 2011 16:46 Go to previous message
Hi Hallvard,
the information from the GenModel is required for the code generation.
The Java code will contain references to the Eclasses that were
generated from the referenced packages. The GenModel provides exactly
the information that is necessary to get this right. It's essentially a
mapping model from EClassifier to a java class name.
Sebastian
> Hallvard
>> Hi,
>> grammar:
>> Rule: {Rule}
>> XExpression)? ';'
>> at
>> ... 43 more
>> Hallvard
>>> Hi,
>>> think.
>>> XExpression)?
>>> Hallvard
Previous Topic:Xpand - surplus white space
Next Topic:Xtext index and referenced JARs
Current Time: Sat Jul 26 00:38:48 EDT 2025
Powered by FUDForum. Page generated in 0.03340 seconds
