Home » Language IDEs » AspectJ » aspectj + ant
aspectj + ant [message #690959] Thu, 30 June 2011 09:21 Go to next message
I generate an aspect (with annotation) in a java project and i compile it with ant using the following code :
<taskdef resource="org/aspectj/tools/ant/taskdefs/aspectjTaskdefs.properties">
<classpath>
<pathelement location="lib/aspectjtools.jar"/>
</classpath>
</taskdef>
<target name="compile">
<mkdir dir="${buildfolder}"/>
<property name="ajc"
value="org.aspectj.tools.ant.taskdefs.Ajc11CompilerAdapter"/>
<javac srcdir="src" destdir="${build}" classpathref="lib.classpath">
<compilerarg compiler="${ajc}" />
</javac>
</target>
the lib.classpath ~ the folder lib
and in the folder "lib" i put aspectjtools.jar ,aspectjrt.jar
when i launch the target i get myAspect.class but without aspectj informations like
public static EntryAspect aspectOf()
if(ajc$perSingletonInstance == null)
throw new NoAspectBoundException("aspects.EntryAspect", ajc$initFailureCause);
} else
return ajc$perSingletonInstance;
any idea ?
wich compiler can i use javac or iajc or ajc ????
how can i compile aspectj plugins using ant task ????
thanks in advance .
Re: aspectj + ant [message #691082 is a reply to message #690959] Thu, 30 June 2011 12:44 Go to previous messageGo to next message
iajc is the best ant task to be using for compiling AspectJ code in ant. See the docs here:
http://www.eclipse.org/aspectj/doc/next/devguide/antTasks-iajc.html
What do you mean by AspectJ plugins? Eclipse plugins?
Re: aspectj + ant [message #691335 is a reply to message #691082] Fri, 01 July 2011 04:58 Go to previous messageGo to next message
Hi Andrew,
I mean by Aspectj plugins : plugins eclipse wich contains aspects (aspect with
annotation) .
when i use iajc compiler in order to compile my aspect using ant
<iajc sourceroots="src/aspects" classpathref="aspect.classpath" source="1.5" target="1.5" />
i get this error :
The method getVersion() is undefined for the type Bundle.
because i have in my aspect the instructions :
org.osgi.framework.Bundle bundle = protectionDomain.getBundle();
org.osgi.framework.Version = bundle .getVersion();
i add the org.eclipse.osgi_3.6.1.R36x_v20100806.jar plugin wich contains the
org.osgi.framework.Version class but i always get the same compilation error.
it is a iajc problem ? (i get the same error using javac compiler!!!!!)
any idea ?
thanks in advance.
Re: aspectj + ant [message #691673 is a reply to message #691335] Fri, 01 July 2011 22:25 Go to previous message
I am guessing that the problem happens because you are not properly adding the osgi bundle to the compile task in your ant file. In the ant file snippet above, I see no reference to that classpath element.
Underneath
You will need to add something like:
<pathelement location="path_to_eclipse/plugins/org.eclipse.osgi_3.6.1.R36x_v20100806.jar"/>
Previous Topic:Update Site for Old Versions
Next Topic:Pointcut with annotations
Current Time: Fri Jun 06 17:26:12 EDT 2025
Powered by FUDForum. Page generated in 0.65148 seconds
