Home » Archived » BIRT » Where can I find logs? (Where can I find logs? )
Where can I find logs? [message #690333] Wed, 29 June 2011 07:50 Go to next message
Hi All,
I am creating BIRT reports using the BIRT report designer in Eclipse.
I want to know where can i get (BIRT Logs)SQL queries which are internally executed.
I have tried configuring the Level of logging to in the web.xml as specified in the eclipse birt wiki.
The location of the eclipse id as follows :
D:\eclipse\plugins\org.eclipse.birt.report.viewer_2.6.2.r262_v20110214\birt\WEB-INF
Any help would be highly appreciated.
Parasuram
(no subject) [message #690468 is a reply to message #690333] Wed, 29 June 2011 10:53 Go to previous messageGo to next message
This is an issue in the designer.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=280851
You may want to look at the following post as an alternative:
http://birtworld.blogspot.com/2010/01/quick-and-dirty-logging.html
Jason
On 6/29/2011 7:50 AM, parasu wrote:
> Hi All,
> Thanks
> Parasuram
Re: (no subject) [message #690850 is a reply to message #690468] Thu, 30 June 2011 06:25 Go to previous messageGo to next message
Hi Jason,
Even i am facing similar kind of problem, i am unable to see the sql queries fired by BIRT to generate the report output.
I am developing a simple report without any java classes or even javascript.
I am a newbie to BIRT your help regarding using java script or any other alternate means to get the logs would be highly appreciated.
Re: (no subject) [message #691045 is a reply to message #690850] Thu, 30 June 2011 11:15 Go to previous messageGo to next message
Entering script is pretty easy. Can you try clicking on your dataset
then hit the script tab on the report canvas and entering a beforeOpen
script, something like:
importPackage( Packages.java.io );
out = new PrintWriter( new FileWriter( "c:/temp/myquery.txt", true ) );
out.println( "My Query: " + this.queryText);
out.close();
Jason
On 6/30/2011 6:25 AM, Praveen Jain wrote:
> Hi Jason,
> javascript.
> Thanks
Re: Where can I find logs? [message #692856 is a reply to message #690333] Tue, 05 July 2011 07:01 Go to previous messageGo to next message
Thanks Jason,
Using the provided script i am able to see the sql queries executed while report generation.But i am not able to see the parameters passed.
could you please also suggest how to check the parameter for null value in the script. a simple example would be greatly helpfull.
[Updated on: Tue, 05 July 2011 07:26] by Moderator
(no subject) [message #692987 is a reply to message #692856] Tue, 05 July 2011 10:34 Go to previous message
Are these dataset parameters or report parameters? To check a report
parameter do something like:
if( params["NewParameter"].value == null ){
Jason
On 7/5/2011 7:01 AM, parasu wrote:
> Thanks Jason,
> Also when i preview the report once the query is logged in the file
> multiple times(12times)
Previous Topic:Problems loading org.eclipse.birt.report.data.oda.jdbc with BIRT 3.7
Next Topic:Report parameters
Current Time: Fri Jul 25 22:22:07 EDT 2025
Powered by FUDForum. Page generated in 0.24322 seconds
