| Re: Call for testers: GMF Tooling 2.4.0 release candidate [message #691275 is a reply to message #690943] |
Fri, 01 July 2011 02:45  |
Hi Mickael,
I now tried to use a the with helios generated code with indigo and it did work fine. It must be related to the code generation of indigo. I use custom templates but I do not think that they should effect this. I will investigate further and open a bug as soon as I can specify the behaviour in more detail.
ralph.
Do you have custom templates for generation?
Can you open a bug for that, and please attach your gmf conf files to it?
On 30/06/2011 09:23, ralph. wrote:
> Hi Mickael,
> this generated code
> /** Creates a connection editpart. */
> final protected org.eclipse.gef.ConnectionEditPart
> createConnection(Object connectionView) {
> return (org.eclipse.gef.ConnectionEditPart) createChild(connectionView);
> Causes the following Exception:
> Quote:
>> java.lang.ClassCastException:
>> xxx.diagram.edit.parts.WrappingLabel7EditPart
>> cannot be cast to org.eclipse.gef.ConnectionEditPart
>> at
>> org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.createConnection(GraphicalEditPart.java:269)
>> at
>> org.eclipse.gef.editparts.AbstractGraphicalEditPart.createOrFindConnection(AbstractGraphicalEditPart.java:339)
>> at
>> org.eclipse.gef.editparts.AbstractGraphicalEditPart.refreshTargetConnections(AbstractGraphicalEditPart.java:759)
>> at
>> org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh(AbstractGraphicalEditPart.java:646)
>> at
>> org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.access$3(GraphicalEditPart.java:1)
>> at
>> org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart$3.run(GraphicalEditPart.java:861)
>> at
>> org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.runExclusive(TransactionalEditingDomainImpl.java:328)
>> at
>> org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.refresh(GraphicalEditPart.java:851)
>> at
>> org.eclipse.gef.editparts.AbstractEditPart.addNotify(AbstractEditPart.java:253)
>> at
>> org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotify(AbstractGraphicalEditPart.java:223)
>> at
>> org.eclipse.gef.editparts.AbstractEditPart.addChild(AbstractEditPart.java:212)
>> at
>> org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.addChild(GraphicalEditPart.java:1319)
>> at
>> org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(AbstractEditPart.java:781)
>> at
>> org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractEditPart.java:726)
>> at
>> org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh(AbstractGraphicalEditPart.java:644)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> org.eclipse.gef.editparts.SimpleRootEditPart.setContents(SimpleRootEditPart.java:105)
>> at
>> org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents(AbstractEditPartViewer.java:617)
>> at
>> org.eclipse.gmf.runtime.diagram.ui.parts.DiagramGraphicalViewer.setContents(DiagramGraphicalViewer.java:352)
>> at
>> org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents(AbstractEditPartViewer.java:626)
>> at
>> org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.initializeGraphicalViewerContents(DiagramEditor.java:872)
>> at
>> org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.initializeGraphicalViewer(DiagramEditor.java:865)
>> at
>> org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditorWithFlyOutPalette.initializeGraphicalViewer(DiagramEditorWithFlyOutPalette.java:116)
>> at
>> org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.DiagramDocumentEditor.initializeGraphicalViewer(DiagramDocumentEditor.java:174)
>> at
>> org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.createGraphicalViewer(DiagramEditor.java:807)
>> at
>> org.eclipse.gef.ui.parts.GraphicalEditor.createPartControl(GraphicalEditor.java:171)
>> at
>> org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.createPartControl(DiagramEditor.java:1580)
>> at
>> org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditorWithFlyOutPalette.createPartControl(DiagramEditorWithFlyOutPalette.java:328)
>> at
>> org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.DiagramDocumentEditor.createPartControl(DiagramDocumentEditor.java:1510)
>> at
>> org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
>> at
>> org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
>> at
>> org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
>> at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
>> at
>> org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
>> at
>> org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
>> at
>> org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
>> at
>> org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
>> at
>> org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1245)
>> at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1198)
>> at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1597)
>> at org.eclipse.ui.internal.PartStack.add(PartStack.java:493)
>> at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
>> at org.eclipse.ui.internal.PartStack.add(PartStack.java:479)
>> at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
>> at
>> org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
>> at
>> org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
>> at
>> org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
>> at
>> org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:808)
>> at
>> org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:707)
>> at
>> org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:666)
>> at
>> org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2942)
>> at
>> org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
>> at
>> org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
>> at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
>> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
>> at
>> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
>> at
>> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
>> at
>> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2764)
>> at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
>> at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
>> at
>> org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:355)
>> at
>> org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:164)
>> at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:249)
>> at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:228)
>> at
>> org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:275)
>> at
>> org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:251)
>> at
>> org.eclipse.jdt.internal.ui.navigator.OpenAndExpand.run(OpenAndExpand.java:50)
>> at org.eclipse.ui.actions.RetargetAction.run(RetargetAction.java:221)
>> at
>> org.eclipse.ui.navigator.CommonNavigatorManager$3.open(CommonNavigatorManager.java:185)
>> at
>> org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
>> at
>> org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:866)
>> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
>> at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
>> at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
>> at
>> org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:864)
>> at
>> org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1152)
>> at
>> org.eclipse.ui.navigator.CommonViewer.handleOpen(CommonViewer.java:462)
>> at
>> org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1256)
>> at
>> org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:275)
>> at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:269)
>> at
>> org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:309)
>> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
>> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
>> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
>> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
>> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
>> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
>> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
>> at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
>> at
>> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
>> at
>> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
>> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
>> at
>> org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
>> at
>> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
>> at
>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
>> at
>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
>> at
>> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
>> at
>> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
>> at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
>> at java.lang.reflect.Method.invoke(Unknown Source)
>> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
>> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
>> at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
>> at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
FUDForum. Page generated in 0.04789 seconds
