Home » Archived » Buckminster » setting build.id in about.mappings
setting build.id in about.mappings [message #690717] Thu, 30 June 2011 00:47 Go to next message
Originally posted by: Blue
I'm using buckminster to build my project, and I added the token @build@
to my about.mappings and I was expecting buckmister to replace it with
the build timestamp, but In my About box I see the text ${build.id}. I'm
assuming I'm missing a step, but Not sure what is it.
I need to set the build.id to the timestamp of the build.
Any help?
Re: setting build.id in about.mappings [message #690736 is a reply to message #690717] Thu, 30 June 2011 01:51 Go to previous messageGo to next message
If you pass -Dbuild.id=<your build id> when you perform your site.p2 action, you should be all set. Some more info can
be found here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=309144
- thomas
On 2011-06-30 06:47, Blue wrote:
> I'm using buckminster to build my project, and I added the token @build@ to my about.mappings and I was expecting
> buckmister to replace it with the build timestamp, but In my About box I see the text ${build.id}. I'm assuming I'm
> Any help?
Re: setting build.id in about.mappings [message #690744 is a reply to message #690736] Thu, 30 June 2011 02:22 Go to previous messageGo to next message
> action, you should be all set. Some more info can be found here:
Thanks, this is useful, I looked in Buckminster book, but couldn't find
any info about build id
Now, how can I synchronize the timestamp used for the plugins qualifier
and the build.id ?
Also I want to format the build.id to contain Hudson build id, and the
timestamp used for plugins qualifier.
Re: setting build.id in about.mappings [message #690745 is a reply to message #690744] Thu, 30 June 2011 02:25 Go to previous messageGo to next message
> and the build.id ?
More clarification. I tried to use Hudson variable $BUILD_ID in the
buckminster.properties file, but I got Exceptions from Buckminster while
it was trying to parse the format.
Also, if I ignored Hudson for now, How can I use timestamp generator in
buckminster.properties and use the same timestamp for build.id property?
Re: setting build.id in about.mappings [message #690829 is a reply to message #690745] Thu, 30 June 2011 05:30 Go to previous message
The Buckminster property expansion falls back to Eclipse variable
expansion so this should work:
build_id = ${env_var:BUILD_ID}
That timestamp will differ between projects. It finds the last
modification in the subtree and uses that so it's not suitable to use as
a build_id.
- thomas
Previous Topic:Buckminster code-base has moved to Git
Next Topic:Circular Component Dependency Issue with JDT
Current Time: Tue Sep 16 07:20:50 EDT 2025
Powered by FUDForum. Page generated in 0.05001 seconds
