[Embedded Birt] : Migration to 3.7 [message #690269] |
Wed, 29 June 2011 05:53  |
Hi everybody,
I plan to migrate to Birt 3.7 version.
We have embedded Birt engine into our application as many of you have done.
According to the wiki migration page (htp://wiki.eclipse.org/Birt_3.7_Migration_Guide), external runtime is no more necessary,
nor the following code : config.setBIRTHome("pathtoruntime");
Only add all ReportEngine/lib jars to application classpath (WEB-INF/lib for example) is required.
Comparing Birt 2.6.2 to 3.7 version, I note that there are many more libraries (24 vs 78).
I can guess that some of them are optional, but is there any documentation about library requirement and feature ?
The aim is :
- I want to avoid as much as possible library conflict.
- As Birt libraries are still not publish on any maven repository, I would like to create my own maven descriptor file and publish Birt libraries on my local maven proxy.
Thanks you for any help.
Best Regards,
Nicolas
Re: [Embedded Birt] : Migration to 3.7 [message #690452 is a reply to message #690269] |
Wed, 29 June 2011 10:29   |
Nicolas
There are more libs because the runtime jars are no longer in the
platform/plugins directory. All the birt functionality is one jar. The
only jars that I see that could be trimmed are the datatools jars, which
have jars for different data source types. You could also remove
derby.jar if you do not want to use the sample db.
Jason
On 6/29/2011 5:53 AM, miaou wrote:
> Hi everybody,
> no more necessary, nor the following code :
> The aim is :
> Best Regards,
> Nicolas
FUDForum. Page generated in 1.20060 seconds
