Home » Archived » BIRT » use parameterPage tag to run report in same JSP page
use parameterPage tag to run report in same JSP page [message #690455] Wed, 29 June 2011 10:42 Go to next message
HI,
I'm using parameterPage tag to build a custom parameter page, but when the report is run, it's either in a new window or overwrite the current window....(by setting thetarget tab to _blank or parent)
Is there a way to run the report below the parameter field, like what report tag and viewer tag do with the isHostpage tag..... Since isHostpage is not supported by parameterPage tag.
Thank in advance
[Updated on: Wed, 29 June 2011 11:02] by Moderator
Re: use parameterPage tag to run report in same JSP page [message #690513 is a reply to message #690455] Wed, 29 June 2011 11:14 Go to previous messageGo to next message
Why not use a frameset like:
<%@ page language="java" contentType="text/html; charset=ISO-8859-1"
pageEncoding="ISO-8859-1"%>
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
"http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1">
<title>Insert title here</title>
</head>
<frameset rows="*,2*">
<frame name="parms" src="BirtParmCustomTarget.jsp">
<frame name="content" src="">
</frameset>
</html>
Then use BirtParmCustomTarget.jsp
<%@ taglib uri="/birt.tld" prefix="birt" %>
<html>
<head>
</head>
<body>
<div id=myudiv></div>
<birt:parameterPage id="birtParmPage" reportDesign="TopNPercent.rptdesign"
name="my form"
pattern="frameset"
height="600"
width="800"
format="html"
title="My Viewer Tag"
isCustom="true"
showTitle="true"
showToolBar="true"
showNavigationBar="true"
target="content"
TOP COUNT PARAMETER
<input type="Text" name="Top Count">
<br><br>
TOP PERCENT PARAMETER
<input type="Text" name="Top Percentage">
<br><br>
<input type="Submit" value="Run Report">
</birt:parameterPage>
</body>
</html>
Jason
On 6/29/2011 10:42 AM, Scroon wrote:
> HI,
> report and viewer do with the isHostpage tag..... Since isHostpage is
> Thank in advance
Re: use parameterPage tag to run report in same JSP page [message #690542 is a reply to message #690513] Wed, 29 June 2011 12:59 Go to previous messageGo to next message
Thanks, it works great Surprised
Re: use parameterPage tag to run report in same JSP page [message #741230 is a reply to message #690455] Wed, 19 October 2011 06:09 Go to previous messageGo to next message
Hey I am new to BIRT as well as JSP.
I am also doing to the same thing but I am getting an error of NoClassDefFoundError. Please help me out of this. Let me know which jar files I have to add in class path.
Gaurav
Re: use parameterPage tag to run report in same JSP page [message #741461 is a reply to message #741230] Wed, 19 October 2011 10:56 Go to previous message
Gaurav,
The example that was posted earlier in this thread was just a JSP page
that I added to the deployed BIRT Viewer. Is this what you are doing?
Jason
> Gaurav
Previous Topic:Table (id=585) - Can not load the report query
Next Topic:Alignment of labels in bar chart
Current Time: Sun Jul 27 02:18:36 EDT 2025
Powered by FUDForum. Page generated in 0.04887 seconds
