Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EEF] Stabillity
[EEF] Stabillity [message #690234] Wed, 29 June 2011 04:40 Go to next message
Hi All,
We plan to use EEF in a substantial way.
Since EEF is still in incubation phase we would like to know how much stable it be ?
and what are its plan to mature ?.
I am bit speculative here because we had adopted one incubated project earlier and ended up facing difficulties in terms of support and APIs Smile.
cheers,
Saurav
Re: [EEF] Stabillity [message #690274 is a reply to message #690234] Wed, 29 June 2011 05:48 Go to previous messageGo to next message
Originally posted by:
Hi saurav,
Well, EEF 1.0.0 is not incubating anymore and is stable enough to be
used in production mode.
BTW, EEF is very dependent of your metamodel and the way the EEF models
are made. To be more specific, if you have hundreds metaclasses and for
each you want to generates 1 component and 2 views, EEF will not be very
fast for generation. you should customize the default initialization of
your eef models by using references between views and components, and to
generates only the views for the edited metaclass of your model.
For more little metamodels, EEF will not have any performance problems (
generation and runtime ).
hope that helps,
Le 29/06/2011 10:40, saurav a écrit :
> Hi All,
> stable it be ?
> earlier and ended up facing difficulties in terms of support and APIs :).
> cheers,
> Saurav
Stéphane Bouchet, OBEO
Re: [EEF] Stabillity [message #690294 is a reply to message #690274] Wed, 29 June 2011 06:23 Go to previous messageGo to next message
Hi Stéphane,
I understand your point of Having less views for bigger metamodels.
And the website seems to be misleading, still depicting it as an incubation project http://www.eclipse.org/modeling/emft/?project=eef Smile
cheers,
Saurav
Re: [EEF] Stabillity [message #690392 is a reply to message #690294] Wed, 29 June 2011 09:07 Go to previous message
Le 29/06/2011 12:23, saurav a écrit :
> Hi Stéphane,
> incubation project http://www.eclipse.org/modeling/emft/?project=eef :)
the website is for EMFT, not for EEF itself ( the paragraph says : "Some
components are currently in their Validation (Incubation) Phase."
EMFT is the incubation project of Eclipqe modeling, and we will move
soon to the EMF project. Doing this, we will loose our "incubating egg" :)
> cheers,
> Saurav
Previous Topic:EMFIndex still an active projecct?
Next Topic:[TEXO] Containment references
Current Time: Fri Jul 25 22:56:28 EDT 2025
Powered by FUDForum. Page generated in 0.05753 seconds
