multi-reference transformation problem [message #689768] |
Tue, 28 June 2011 06:13  |
Dear All,
I am currently writing a code to make model transformation using ATL. What is currently happening is that, when i try to make transformation which has multiple references, where one classes references to the other class which the other class also is referenced to the other class, and my situation is i have to keep the references respectively. During this transformation, i am getting the following result on my xmi target model,
<attributeTypes attributeType="/0/@types"/> where attributeTypes contains a reference to AttributeType, However the content to the class AttributeType is listed out of the intended class. And btw i do not know where "/0/@types"/ comes from and what it means. The other issue is when i make transformation, there are some attributes which does not show up at the result, and i do not know the reason why they do not show up at the target model. Is there any one who is getting same outputs? Please share what happened and how did solve it. Let me give u the code i am using to make the transformation
rule transfor1
from i: XML!Element(i.name = 'XX')
to o: Model2!classA(
attributeTypes <- atypes,
types <- i.children ->select(c|c.oclIsKindOf(XML!Element)) -> asSequence()
atypes:Model2!AttributeTypes(
attributeType <- i.children -> select(c|c.oclIsKindOf(XML!Element) ->asSequence()
rule Types
from i:XML!Element(i.name = 'Types')
to o:Model2!Types(
xx <- i.children ->select(c|c.oclIsKindOf(XML!Element) -> asSequence(), --reference
yy <- i.children ->select(c|c.oclIsKindOf(XML!Element) -> asSequence() --this is another reference
rule AttributeType
from i:XML!Element(i.name = 'AttributeType')
to o:Model2!AttributeType(
name <- i.getAttrVal('name'), --- this is an attribute
rr <- i.children -> select(c|c.oclIsKindOf(XML!Element)) -> asSequence --this is another reference
and the output i am getting is:
<XML:classA>
<type>
<xx/>
<yy/>
</type>
</XML:classA>
<XML:AttributeType name="SDVA"/>
does "/0/@types" mean it is referenced to the last line which is XML:AttributeType name = "SDVA" ? I am not sure how data, nodes and stuff are organized but my guess is that if it was the right one it would have been like
<XML:classA>
<type>
<xx/>
<yy/>
</type>
<attributeTypes>
<AttributeType name="SDVA"/>
<AttributeTypes/>
</XML:classA>
I need it very badly, please help if there is someone with the same problem.
Thanks in advance
Re: multi-reference transformation problem [message #689974 is a reply to message #689768] |
Tue, 28 June 2011 12:42   |
Comments below.
On 28/06/2011 3:13 AM, Emwedish wrote:
> Dear All,
> xmi target model, <attributeTypes attributeType="/0/@types"/> where
> means.
It's path to navigate the first object at the root of the same resource
and then to the types reference of that object.
> rule transfor1
> asSequence()
> select(c|c.oclIsKindOf(XML!Element) ->asSequence() )
> rule Types
> to o:Model2!Types(
> rule AttributeType
> <XML:classA>
> <type>
> <xx/>
> <yy/>
> </type>
> </XML:classA>
> <XML:classA>
> <type>
> <xx/>
> <yy/>
> </type>
> <attributeTypes>
> <AttributeTypes/>
> </XML:classA>
> problem.
> Thanks in advance
FUDForum. Page generated in 0.07712 seconds
