Home » Eclipse Projects » Remote Application Platform (RAP) » Classpath problem
Classpath problem [message #69002] Sun, 06 January 2008 07:39 Go to next message
Hello
I am trying to develop RAP app that uses EMF & TENEO.
So I need to use some 3rd part libs like hibernate3.jar.
I have added them to the plugin, everything compiles fine, but when
trying to use teneo features I get:
WARNING: Error for /rap;jsessionid=4v324dv553wh4?nocache=1199623041862
java.lang.NoClassDefFoundError: org/hibernate/Session
Am I doing something wrong?
Chris
Re: Classpath problem [message #69562 is a reply to message #69002] Wed, 09 January 2008 14:23 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Chris,
there shouldn't be any difference between including a library into RAP
and including a library into RCP or any other OSGi based application
A simple example compiles and runs fine, the relevant part of the
MANIFEST.MF looks like this:
Bundle-ClassPath: lib/my-lib.jar,
Just a wild guess: could it be that hibernate itself depends on some
library that is not on your class path?
I you can strip down your project to the relevant (not-working) parts,
feel free to post it here and we could have a look at it.
Rüdiger
Christopher Daniel wrote:
> Hello
> Chris
Re: Classpath problem [message #69739 is a reply to message #69562] Thu, 10 January 2008 16:35 Go to previous messageGo to next message
Thanks Rudiger!
I have found the problem: bundle-classpath was empty. I have always
thought that adding jar to build path is enough, but aparently I was wrong.
Thanks once more.
Chris
Re: Classpath problem [message #69759 is a reply to message #69739] Thu, 10 January 2008 16:40 Go to previous message
In Eclipse 3.4, there's a compiler option within PDE called "Bundle
classpath synchronization"
If you set that to true, it will catch cases like this.
~ Chris
Previous Topic:FocusGained Events from custom Buttons
Next Topic:Servlet Context Integration
Current Time: Mon Nov 03 15:56:22 EST 2025
Powered by FUDForum. Page generated in 0.03599 seconds
