Home » Eclipse Projects » GEF » Create a Figure not connectable
| Create a Figure not connectable [message #68769] |
Sun, 09 March 2003 18:51  |
Originally posted by: truenoto.yahoo.com
What is the easiest way to create a Figure in draw2d not connectable?
For example, in the Logic example, how to make Ground Output Figure NOT
connectable?
| Re: Create a Figure not connectable [message #69272 is a reply to message #68984] |
Tue, 11 March 2003 11:15   |
I would like to do this:
User can draw a wire between an AND gate and a OR gate, but not an AND gate
and a Circuit. I would like to show this interactively to the user, i.e.
when user clicks on AND gate to start a wire, and the he moves the mouse to
the OR gate, the plug icon shows up, but when he moves the icon to the
Circuit , it shows a STOP icon.
Where should I put this check? in the EditPolicy? or in the place where the
editpart return the connection anchor (return null, if the wire is not
allow)?
Thanks for your quick response.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:b4ieal$5m0$1@rogue.oti.com...
> You're right. Sorry, I used the wrong term. I should have said
> GraphicalNodeEditPolicy. The things at the ends of connections are
"nodes".
> "Takumi Fujiwara" <truenoto@yahoo.com> wrote in message
> news:b4idcq$4id$1@rogue.oti.com...
> > Thanks.
> > That tells me why a "Wire" is connectable, it install a
> > ConnectionEndpointEditPolicy.
> > Could you tell me why I can not connect to "Label" but I can connect to
> > "LiveOutput" with a Wire? in the logic example?
> > Thanks.
> > news:b4gsmf$433$1@rogue.oti.com...
> > > Are you asking how to make an EditPart not connectable? By default,
an
> > > EditPart doesn't understand any request. So, it only *becomes*
> > connectable
> > > when you install a ConnectionEndpointEditPolicy. Without this policy,
> the
> > > part will never be identified as a "target" for connection operations.
> > > news:b4gkga$gl$1@rogue.oti.com...
> > > > Hi,
connectable?
> NOT
> > > > connectable?
> > > > Thanks
| Re: Create a Figure not connectable [message #69313 is a reply to message #69272] |
Tue, 11 March 2003 13:42  |
news:b4l2gt$1pf$1@rogue.oti.com...
gate
to
the
> allow)?
The GraphicalNodeEditPolicy is being installed in CircuitEditPart's
super-superclass, LogicEditPart. If you overwrite the EditPolicy with null,
you will get exactly what you describe. So, in circuit editpart:
createEditPolicies() {
super.createEditPolicies();
installEditPolicy(EditPolicy.SELECTION_FEEDBACK_ROLE, new
ContainerHighlightEditPolicy());
//ADDED LINE FOLLOWS!!
installEditPolicy(EditPolicy.GRAPHICAL_NODE_ROLE, null);
Current Time: Tue Nov 04 20:11:30 EST 2025
Powered by FUDForum. Page generated in 0.05752 seconds
