Home » Eclipse Projects » Eclipse Scout » NullPointerException when connecting to http://localhost/TutorialMiniCrm/process
NullPointerException when connecting to http://localhost/TutorialMiniCrm/process [message #689713] Tue, 28 June 2011 04:29 Go to next message
Hi, I am absolutely new to scout. I read the tutorials, consumed to webinar and read the documentation as far. Because this project seems to be interesting I installed to minicrm tutorial. After started the server, I try to connect via the browser. While connecting there is a npe thrown:
HTTP ERROR 500
Problem accessing /TutorialMiniCrm/process. Reason:
INTERNAL_SERVER_ERROR
Caused by:
at org.eclipse.scout.rt.shared.services.common.security.ACCESS.check(Unknown Source)
at org.eclipse.scout.rt.server.admin.html.view.ServicesView.isVisible(Unknown Source)
at org.eclipse.scout.rt.server.admin.html.view.TopView.produceBody(Unknown Source)
at org.eclipse.scout.rt.server.admin.html.AdminSession.serviceRequest(Unknown Source)
at org.eclipse.scout.rt.server.ServiceTunnelServlet.doGet(Unknown Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.eclipse.scout.http.servletfilter.HttpServletEx.access$0(Unknown Source)
at org.eclipse.scout.http.servletfilter.HttpServletEx$1.service(Unknown Source)
at org.eclipse.scout.http.servletfilter.internal.FilterChainImpl.doFilter(Unknown Source)
at org.eclipse.scout.rt.server.servlet.filter.AbstractChainableSecurityFilter.doFilterInternal(Unknown Source)
at org.eclipse.scout.rt.server.servlet.filter.AbstractChainableSecurityFilter.access$0(Unknown Source)
at org.eclipse.scout.rt.server.servlet.filter.AbstractChainableSecurityFilter$1.run(Unknown Source)
at javax.security.auth.Subject.doAs(Unknown Source)
at org.eclipse.scout.rt.server.servlet.filter.AbstractChainableSecurityFilter.doFilter(Unknown Source)
at org.eclipse.scout.http.servletfilter.ServletFilterDelegate.delegateServiceMethod(Unknown Source)
at org.eclipse.scout.http.servletfilter.HttpServletEx.service(Unknown Source)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:126)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:317)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:511)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:390)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:182)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:765)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:326)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:542)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:924)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:549)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:212)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:404)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:409)
at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:582)
Powered by Jetty://
What am I doing wrong?
Thank you!
Re: NullPointerException when connecting to http://localhost/TutorialMiniCrm/process [message #689967 is a reply to message #689713] Tue, 28 June 2011 12:45 Go to previous message
Hi Christian
We solved the problem for release 3.7.1 (SR1) on 9/23/2011.
We created a bug on bugzilla you can track at https://bugs.eclipse.org/bugs/show_bug.cgi?id=350606. Please have a look at the proposed workaround on the bug's description until SR1 is published.
If you have any further questions, please let me know.
[Updated on: Wed, 29 June 2011 03:31] by Moderator
Previous Topic:WebStart with Scout
Next Topic:AbstractTable: Dynamic Columns
Current Time: Sun Jul 27 10:02:35 EDT 2025
Powered by FUDForum. Page generated in 0.03815 seconds
