Generate parameter value from report dataset [message #689462] |
Mon, 27 June 2011 12:57  |
I have a report design which has two parameters. Is is possible that, while the data for the one parameter comes from my application, the data for the second comes dynamically from another dataset which uses the first parameter to retrieve the value of the second parameter?
I have created the situation above but the value of the second parameter always resorts to the default value I supplied when I created the param.
I have other ways of doing this but if this can be done it would be very helpful.
FYI - I'm using BIRT 2.3.2
Thanks in advance,
Don
FUDForum. Page generated in 0.08743 seconds
