Home » Modeling » GMF (Graphical Modeling Framework) » GMF/TENEO/Common Navigator Framework
GMF/TENEO/Common Navigator Framework [message #668073] Tue, 03 May 2011 11:45 Go to next message
Hello everyone,
I´ve developed a GMF Diagram Editor. All diagrams are stored in databases with Teneo.
Now, I´m developing a "Diagram explorer" with Common Navigator Framework wich checks for all the diagrams persisted.
I would like to have an action in the CNF explorer wich allows to create new diagrams wich would do the same than creating from File->New->XYZDiagram in the menu bar.
How can I do this?
Thanks in advance,
Joao
Re: GMF/TENEO/Common Navigator Framework [message #689262 is a reply to message #668073] Mon, 27 June 2011 05:36 Go to previous messageGo to next message
Hi Joao,
I think we`re working on similar things Smile
Unfortunately I just a have the same isues but no solution.
Can you provide me some information about how to store multiple GMF-diagrams/editors in a database using teneo?
With kind regards,
Andreas
Re: GMF/TENEO/Common Navigator Framework [message #689882 is a reply to message #689262] Tue, 28 June 2011 10:36 Go to previous messageGo to next message
Hello Andreas,
I think I have the solution for your problem.
Probably you are using an URI like:
hbxml://?dsname=mindmap&query1=from Map&query2=from Diagram
If you want to have severall diagrams in the same database you just have to use an URI like:
hbxml://?dsname=mindmap&query1=from Map&query2=from Diagram where name = XYZ
Where XYZ is the name of the diagram you want to open.
Provide me some feedback later please.
Best Regards,
João Silveira
[Updated on: Tue, 28 June 2011 10:36] by Moderator
Re: GMF/TENEO/Common Navigator Framework [message #690843 is a reply to message #689882] Thu, 30 June 2011 06:04 Go to previous messageGo to next message
Hi Joao,
I`m still facing some basic issues.
What I try right now is to create a new Diagram (especially with Dialog page) and store this in DB when hitting the OpenmindmapDBeditor-Menuitem. I don`t know how to change the run-action to do this.
Do I have to open multiple sessions to do this or register multiple hibernatestores, too?
Sorry if this is a bit of a noob-question
kind regards
Re: GMF/TENEO/Common Navigator Framework [message #1067856 is a reply to message #690843] Wed, 10 July 2013 18:01 Go to previous message
Hi Joao,
It possible that some tutorial will show me how to use gmf and teneo I would be helpful.
Thank you.
Previous Topic:Changing Palette ToolGroups dynamically in GMF editor
Next Topic:Popup Bar Type
Current Time: Sat Jul 19 00:32:59 EDT 2025
Powered by FUDForum. Page generated in 0.26611 seconds
