Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Problem with Quickstart Guide(@main annotation is missing )
[Acceleo] Problem with Quickstart Guide [message #689040] Sun, 26 June 2011 12:17 Go to next message
Hi All,
I am going through the Quick_Start on the Acceleo wiki (sorry but it won't allow me to post links yet).
When I get to the point of Running the template. Run As -> 1 Launch Acceleo Application
I get the error Selection does not contain a main type (@main annotation is missing in your template)
My template looks like the one in the tutorial AFAICT. Except for the fact I had to remove the http from the URI in this message. It is there in the actual template.
[comment encoding = UTF-8 /]
[module generate('www.eclipse.org/uml2/3.0.0/UML')]
[template public generateElement(c : Class)]
[comment @main /]
[file (c.name,false,'UTF-8')]
Hello, [c.name /] World!
[/file]
[/template]
Any ideas?
--Tim
[Updated on: Sun, 26 June 2011 12:18] by Moderator
SOLVED Re: [Acceleo] Problem with Quickstart Guide [message #689044 is a reply to message #689040] Sun, 26 June 2011 12:42 Go to previous messageGo to next message
You must first Build the project. That is not automatically performed.
Re: SOLVED Re: [Acceleo] Problem with Quickstart Guide [message #689052 is a reply to message #689044] Sun, 26 June 2011 13:02 Go to previous messageGo to next message
By default, Eclipse builds automatically all projects, you should check if you haven't disabled it in the menu "project" -> "build automatically". Several features of the Acceleo tooling like real time errors detection or refactoring need that some/all Acceleo modules involved are built. If this options is deactivated I'll advise you to active it to turn it on for a better experience.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Blog: http://stephanebegaudeau.tumblr.com
Acceleo Documentation: http://docs.obeonetwork.com/acceleo
Re: SOLVED Re: [Acceleo] Problem with Quickstart Guide [message #689060 is a reply to message #689052] Sun, 26 June 2011 13:12 Go to previous message
Thanks Stephane. It was unchecked.
Previous Topic:[Acceleo] Problem with Quickstart Guide
Next Topic:[Acceleo] errors when starting m2t generation
Current Time: Wed Jul 23 14:14:35 EDT 2025
Powered by FUDForum. Page generated in 0.04248 seconds
