Publish working sporadically [message #688831] |
Sat, 25 June 2011 18:32  |
I'm having problems with Publish not working consistantly. I have my workspace/project set to automatic publish. Automatic publish seems to work fine for the first dozen or some saves of Java files but then just stops. A Clean... from the server menu does absolutely nothing at least viewed from the eclipse GUI. If I delete the server and re-add it, publish works again but stops after another dozen or so saves.
This problem started a few weeks ago. I can't correlate it with any specific environment changes, though. Previously it worked fine.
I'm using Eclipse helios and have applied all current updates. Platform is Linux x64 on RHEL 5.3. Publishing to Glassfish 3.1 (located on same host as Eclipse).
Any suggestions?
mike
FUDForum. Page generated in 0.04912 seconds
