Home » Newcomers » Newcomers » Problem create and open project eclipse on Readynas duo with Mac
Problem create and open project eclipse on Readynas duo with Mac [message #688652] Sat, 25 June 2011 03:55 Go to next message
Hi, sorry my english, I am italian.
I have the problem to open or create new procject on readynas duo with Mac Os, but another pc with windows 7, I have no problem, and another application(netbeans) can create new project end open.
The error is "WORKSPACE Unavailable" "Workspace in use or cannot be created, choose a different one.
Thanks..
Re: Problem create and open project eclipse on Readynas duo with Mac [message #688779 is a reply to message #688652] Sat, 25 June 2011 13:15 Go to previous messageGo to next message
I think Eclipse tries to get exclusive access of
<workspace>/.metadata/.lock and if it's not able to do that, it decides
someone else must be using that workspace and refuses. Are you able to
delete that file?
> application(netbeans) can create new project end open. The error is
> a different one.
> Thanks..
Re: Problem create and open project eclipse on Readynas duo with Mac [message #689817 is a reply to message #688779] Tue, 28 June 2011 08:34 Go to previous messageGo to next message
Hi, thanks for answer.
Yes I can delete file, but error to present again. How I can setting the -Dosgi.locking=none as default?.
Re: Problem create and open project eclipse on Readynas duo with Mac [message #689824 is a reply to message #689817] Tue, 28 June 2011 08:43 Go to previous messageGo to next message
I have solved, insert into file config.ini the argument "osgi.locking=none".
For now it seems that works.
Re: Problem create and open project eclipse on Readynas duo with Mac [message #689953 is a reply to message #689817] Tue, 28 June 2011 12:25 Go to previous message
You can edit the eclipse.ini for default arguments.
On 28/06/2011 5:34 AM, newforum wrote:
> Hi, thanks for answer. Yes I can delete file, but error to present
Previous Topic:How to use Meld with Eclipse?
Next Topic:renaming a Class member
Current Time: Wed Jul 23 20:36:33 EDT 2025
Powered by FUDForum. Page generated in 0.07537 seconds
