Home » Eclipse Projects » Rich Client Platform (RCP) » Can I define two View Extensions with different IDs and same class(When i define the view, I have to configure the views extension point.)
Can I define two View Extensions with different IDs and same class [message #688277] Fri, 24 June 2011 06:20 Go to next message
In the view's extension point, i specify the view class and the veiw ID.
Can i have two views(Extensions in the plugin.xml ) which have different view IDs but same view class?
In other words, can two extension points for View have the same view class and different VIew ID?
Is it a good practice to do this? We are facing a situation where we think this is a solution but we do not know what is the impact of this approach.
Please share your thoughts on this approach.
Saurabh
Re: Can I define two View Extensions with different IDs and same class [message #688413 is a reply to message #688277] Fri, 24 June 2011 12:20 Go to previous message
Saurabh,
I don't think that's a problem, but will the two different instances of
the same class behave differently in some way? I.e., what's the goal?
> approach.
> Saurabh
Previous Topic:RCP with C/C++ Editor
Next Topic:pass complex java-objects between viewers or plugins
Current Time: Sun Aug 31 19:15:02 EDT 2025
Powered by FUDForum. Page generated in 0.03612 seconds
