Home » Modeling » Epsilon » Eugenia won't install (easily) in Indigo because Indigo does not include GMF SDK
Eugenia won't install (easily) in Indigo because Indigo does not include GMF SDK [message #688261] Fri, 24 June 2011 05:38 Go to next message
Originally posted by: jendrik.johannes
Hi guys,
I just wanted to let you know:
I just tried to install Eugenia from Epsilon's update site in Indigo
(tried both stable and interim). I always got the following dependency
problem:
"Missing requirement: Epsilon Eugenia (Incubation) 0.9.0.201106111013
(org.eclipse.epsilon.eugenia.feature.feature.group 0.9.0.201106111013)
requires 'org.eclipse.gmf.map 0.0.0' but it could not be found"
After digging into this I found out that the GMF SDK is not included in
Indigo (what the ... ???). If you add the GMF update site, it works:
http://download.eclipse.org/modeling/gmf/update-site/releases/
Unfortunately, this also adds a bunch of other update sites (including a
not existing one) which is a bit annoying.
Anyway, you might consider to configure an 'associateSites.xml' for the
Epsilon update sites that does configure the GMF update site automatically.
Jendrik
Re: Eugenia won't install (easily) in Indigo because Indigo does not include GMF SDK [message #688329 is a reply to message #688261] Fri, 24 June 2011 09:02 Go to previous messageGo to next message
Hi Jendrik,
Many thanks for bringing this to our attention and for suggesting a solution! Incidentally this was something we were discussing yesterday with Antonio and Louis after I tried to install Epsilon atop Indigo. Perhaps not including GMF in the "Install modelling components" wizard is an oversight that may be fixed in SR-1 but we'll definitely chase this with the GMF developers and the Modelling PMC to find out exactly what's happening.
Dimitris
Re: Eugenia won't install (easily) in Indigo because Indigo does not include GMF SDK [message #688342 is a reply to message #688329] Fri, 24 June 2011 09:28 Go to previous messageGo to next message
Hi Jendrik,
Mystery solved: http://twitter.com/#!/bruncedric/status/84249809694892033
Dimitris
Re: Eugenia won't install (easily) in Indigo because Indigo does not include GMF SDK [message #697232 is a reply to message #688342] Fri, 15 July 2011 17:05 Go to previous message
Hi chaps,
I'm a bit slow to the party here. Just in case anyone else needs this too, installing the GMF SDK and Tooling from the following update site seemed to work for me on Indigo (3.7):
http://download.eclipse.org/modeling/gmp/gmf-tooling/updates/dev-snapshots/
Louis.
Previous Topic:ClassCastException on ETL
Next Topic:Accessing elements in the ecore model
Current Time: Sat Jul 26 11:06:23 EDT 2025
Powered by FUDForum. Page generated in 0.48591 seconds
