Home » Language IDEs » PHP Development Tools (PDT) » PHP Syntax highlighting not showing in Svn repository exploring
PHP Syntax highlighting not showing in Svn repository exploring [message #688145] Thu, 23 June 2011 22:57 Go to next message
Hi peoples,
I use eclipse pdt, eclipse helios sr2 (eclipse 3.6.2, pdt 2.2.1, subclipse 1.6.18, svn javahl 1.6.17 )
Syntax highlighting for php files works fin in php perspective, but in svn repository exploring perspective php files are not color coded.
xml files are color coded
diffs of php files from within svn are color coded
but double clicking on a php file to show the repository version just shows as a plain text files.
I can't find any option to change that effects this
*.php is registered under general > content types > text->php content type
*.php has associated editors "php editor", "text editory" under editors > file associations.
both are locked by php content type, php editor is default
Anyone know what options effect the highlighting from SVN?
Re: PHP Syntax highlighting not showing in Svn repository exploring [message #688312 is a reply to message #688145] Fri, 24 June 2011 08:15 Go to previous messageGo to next message
There is no solution for pdt 2.2.1.
Bug 321332 - Eclipse PDT, Unsupported content type when opening PHP file from SVN
pdt 3.0 on Indigo doesn't have this issue itself. (svn repository explorer is not supported still though)
Re: PHP Syntax highlighting not showing in Svn repository exploring [message #688359 is a reply to message #688145] Fri, 24 June 2011 10:05 Go to previous messageGo to next message
Ben K wrote on Thu, 23 June 2011 22:57
I've never tried this feature before, but now that I have, I can see it's very useful. I see the problem with syntax highlighting, too.
I'm using Helios SR2, but with slightly older versions of the Subversion extensions (Subclipse 1.6.17, SVN JavaHL 1.6.15).
I would really like to know how to enable the syntax highlighting, too.
I've noticed that code-folding is enabled. If I hover the pointer over the "+" sign beside a folded PHP function, a panel appears that shows the code with syntax highlighted. If I keep this view of the file from SVN open and switch back to the PHP perspective, the highlighting doesn't change.
Re: PHP Syntax highlighting not showing in Svn repository exploring [message #688363 is a reply to message #688312] Fri, 24 June 2011 10:18 Go to previous messageGo to next message
Too bad there's no "Eclipse IDE for PHP Developers" package for Indigo. According to the Eclipse site:
Due to lack of a package maintainer for the Indigo release there will be no PHP (PDT) package. If you would like to install PDT into your Eclipse installtion you can do so by using the Install New Software feature from the Help Menu and installing the PHP Development Tools (PDT) SDK Feature from the Eclipse Indigo Repo[...]
Re: PHP Syntax highlighting not showing in Svn repository exploring [message #689381 is a reply to message #688363] Mon, 27 June 2011 10:30 Go to previous messageGo to next message
There is no ready to go package available on site, but sure You can install pdt
manually, someone quoted easy how-to.
/dmc
Re: PHP Syntax highlighting not showing in Svn repository exploring [message #690749 is a reply to message #689381] Thu, 30 June 2011 02:57 Go to previous messageGo to next message
ok thanks for your replies,
so to sum up its broken in 2.2.1 and 3.0 svn repository exploring is not supported
Re: PHP Syntax highlighting not showing in Svn repository exploring [message #691289 is a reply to message #690749] Fri, 01 July 2011 03:10 Go to previous message
I installed eclipse indigo, pdt 3 , subclipse1.6.18, data tool platforms
svn repository explorer provides syntax highlighting and works as it should
thanks for the replies guys
Previous Topic:Run as PHP Wen Browser lost in forever land
Next Topic:Eclipse won't send breakpoints to xdebug
Current Time: Thu Jul 24 22:38:58 EDT 2025
Powered by FUDForum. Page generated in 0.27306 seconds
