Home » Eclipse Projects » Platform - User Assistance (UA) » RCP Context Sensitive Help Question
RCP Context Sensitive Help Question [message #687632] Wed, 22 June 2011 18:02 Go to next message
I have added the page key for my view but when I select a component inside that view and click F1, the help system does not pop up and I got the following messages in debug mode.
ContextManager.getContext("com.company.ui.core.view.demoview")
ContextManager.getContext - no context found
Registered Context Provider IDs:
com.syncsort.newbex.ui.core [view.demoview]
ContextManager.getContext("org.eclipse.ui.missing")
I have added this line to my view:
PlatformUI.getWorkbench().getHelpSystem().setHelp(control, "com.company.ui.core.view.demoview");
The name of my plug-in is "com.company.ui.core". I have also added the contexts.xml file:
<contexts>
   <context id="view.demoview">
      <description>This is Demo View</description>
      <topic
         label="Tasks for Demo View"
         href="help/html/tasks/subtopic.html"/>
   </context>
</contexts>
I have also added these lines in plugin.xml:
   <extension
         point="org.eclipse.help.contexts">
      <contexts
         file="help/contexts.xml"/>
   </extension>
Is there anything obvious that I am not doing correctly?
Ronald
[Updated on: Thu, 23 June 2011 10:10] by Moderator
Re: RCP Context Sensitive Help Question [message #687955 is a reply to message #687632] Thu, 23 June 2011 11:16 Go to previous message
Well I found myself answering my questions lately but heck I will put up my solution anyway.
The problem is the context ID. Using "view.demoview" as my context ID is the cause of the problem. DO NOT use any "periods" for your context ID. The "ContextManager.getContext()" call is very sensitive on the use of "periods" to get a hold of the AbstractContextProvider. I changed the ID to "view_demoview" and make the corresponding change to contexts.xml solves the problem.
In DemoView.java,
	public void createPartControl(Composite parent) {
		viewer = new TableViewer(
				parent, SWT.MULTI | SWT.H_SCROLL | SWT.V_SCROLL);
		viewer.setContentProvider(new ViewContentProvider());
		viewer.setLabelProvider(new ViewLabelProvider());
		// Provide the input to the ContentProvider
		viewer.setInput(new String[] {"One", "Two", "Three"});
		// Context-sensitive help
		CoreUtil.setHelpPageKey(viewer.getTable(), "com.company.ui.core." + "view_demoview");
In context.xml,
<contexts>
   <context id="view_demoview">
      <topic
   </context>
</contexts>
In plugin.xml,
   <extension
      <contexts
         plugin="com.company.ui.core"/>
   </extension>
[Updated on: Thu, 23 June 2011 11:27] by Moderator
Previous Topic:(no subject)
Next Topic:Indigo unable to connect to marketplace
Current Time: Sat Jul 19 23:23:19 EDT 2025
Powered by FUDForum. Page generated in 0.05626 seconds
