Home » Eclipse Projects » Plugin Development Environment (PDE) » No available Software Sites while TargetPlatform build
No available Software Sites while TargetPlatform build [message #687871] Thu, 23 June 2011 08:31 Go to next message
Since yesterday, I use Eclipse 3.7
Today, I try to build a new TargetPlatform.
I go Menu -> Window -> Preferences -> Plug-in Develepoment -> TargetPlatform
There I add a new Target Definition -> select "Nothing: Start with an empty target definition" -> Next
Now I try to add a new Location -> Software Site
Inside the DropDown Field are NO sites available.
(Adding a site like http://download.eclipse.org/releases/indigo into the field it works with it)
I looked at my old 3.62 Eclipse, there are all my software site.
Under Eclipse 3.7, I try it with a enhanced Eclipse Moldeling Tools 3.7 download and a fresh Eclipse Classic 3.7 (Windows 32 bit) download
It is a big Bug or a new feature, that there are none of my normal software sites?
Greetings
Heiko
Re: No available Software Sites while TargetPlatform build [message #687926 is a reply to message #687871] Thu, 23 June 2011 10:24 Go to previous messageGo to next message
This is a new feature. The target platform now has its own p2 profile. This means that changes in the workspace install won't mess up your target and vice versa. However, this also means that moving from 3.6 to 3.7 will give you an empty list.
Re: No available Software Sites while TargetPlatform build [message #687945 is a reply to message #687926] Thu, 23 June 2011 10:54 Go to previous message
Hi Curtis,
thanks for clarification,
after reading your post, I also found it inside the PDE Guide -> Whats new. Wink
Previous Topic:Eclipse just shuts down when using home made plugin
Next Topic:How to implement in kind of plug-in dependencies in Eclipse RAP
Current Time: Mon Jul 21 00:08:58 EDT 2025
Powered by FUDForum. Page generated in 0.08528 seconds
