(no subject) [message #687859] |
Thu, 23 June 2011 08:04  |
I have sometimes transactions which commit some more data which takes more than 10 seconds. I get hit by a time out
exception. How can I set this time out to larger value?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
(no subject) [message #687935 is a reply to message #687925] |
Thu, 23 June 2011 10:22  |
Thanks Ronald, I see that you also entered a bugzilla for it.
gr. Martin
On 06/23/2011 04:15 PM, Ronald Krijgsheld wrote:
> Yes, then I expect that it the timeout on the server. On the server the same timeout on the SignalProtocol exists.
> However it is not yet configurable. I worked around it by writing an IAppExtension. With the following implementation
> below.
> I saw in previous mails on the newsgroup that you already have server side code. So if you have a way to get the session
> on the server you can just get the protocol and set the timeout there.
> It reminds me that I promised Eike to create an bugzilla for this.
> - Ronald
> public class TestAppExtension implements IAppExtension {
> @Override
> public void start(File configFile) throws Exception {
> IRepository repository = CDOServerUtil.getRepository(IPluginContainer.INSTANCE, "test");
> repository.getSessionManager().addListener(new IListener() {
> @Override
> public void notifyEvent(IEvent event) {
> if (event instanceof SingleDeltaContainerEvent<?>) {
> SingleDeltaContainerEvent<?> e = (SingleDeltaContainerEvent<?>) event;
> if (e.getSource() instanceof InternalSessionManager && e.getDeltaKind() == IContainerDelta.Kind.ADDED) {
> InternalSession s = (InternalSession) e.getDelta().getElement();
> ((SignalProtocol<?>) s.getProtocol()).setTimeout(60 * 1000L);
> @Override
> public void stop() throws Exception {
> On 23-6-2011 15:59, Martin Taal wrote:
>> Hmm, that timeout setting did not influence the behavior. Need to check
>> further.
>> gr. Martin
>> On 06/23/2011 02:17 PM, Ronald Krijgsheld wrote:
>>> After looking at the stacktrace I am not so sure anymore.
>>> look at the thread:
>>> [CDO] TimeoutException on server , what could cause this?
>>> I implemented an CDO server extension that sets the timeout, before
>>> Eike suggested how to do this. I did not have time
>>> to try it that way.
>>> - Ronald
The Netherlands
FUDForum. Page generated in 0.04547 seconds
