Home » Eclipse Projects » Equinox » Where is the source code for org.eclipse.osgi.services?
Where is the source code for org.eclipse.osgi.services? [message #68754] Fri, 23 June 2006 13:32 Go to next message
I've noticed that the source for org.eclipse.osgi.services is not
distributed with the equinox or eclispe sdks. Also, I cannot find it in
the CVS repository. Can someone please direct me to it's location.
Thanks much,
Cameron.
Re: Where is the source code for org.eclipse.osgi.services? [message #68775 is a reply to message #68754] Fri, 23 June 2006 15:21 Go to previous message
Originally posted by: skaegi.sympatico.ca
Hi Cameron,
If you check-out the "org.eclipse.osgi.services" project from CVS the
source is automatically associated with the .class files. If you just need
the source you can find it in the root of the project in src.zip.
I'm not sure why it isn't being associated correctly when you import as a
source plugin?? Perhaps you should open a bug.
-Simon
Previous Topic:Define extension locations using command line arguments
Next Topic:Equinox, the EPL, and the GPL
Current Time: Tue Jul 22 02:02:43 EDT 2025
Powered by FUDForum. Page generated in 0.03085 seconds
