Home » Language IDEs » C / C++ IDE (CDT) » CDT does not build my projects: Build Error
CDT does not build my projects: Build Error [message #68190] Sun, 04 May 2003 23:16 Go to next message
Originally posted by: krystianson.hotmail.com
I'm using eclipse 2.1 and cdt 1.0.1 on a WindowsXP system with
MinGW-2.0.0-3 installed, and my makefile looks like (I've the build
settings setup up to use it):
objects = hello.o
hello : $(objects)
gcc -o hello $(objects) -L C:/MinGW/lib/gcc-lib/mingw32/3.2/ -lstdc++
$(objects) : hello.cpp
gcc -c hello.cpp
all :
${MAKE} hello
PHONY : clean
clean :
-del hello.exe $(objects)
But I get the following error:
Build Error
(Exec error:Launching failed)
Re: CDT does not build my projects: Build Error [message #68202 is a reply to message #68190] Sun, 04 May 2003 23:47 Go to previous messageGo to next message
Sorry, my bad. I got it all figured out: it turns out that make is not in
the same directory that gcc is in, so I just had to append to my path
variable (gcc is in C:\\MinGW\\bin, while make is in the
C:\\msys\\1.0\\bin)
Re: CDT does not build my projects: Build Error [message #68684 is a reply to message #68202] Tue, 06 May 2003 03:24 Go to previous messageGo to next message
> C:\\msys\\1.0\\bin)
the 'make' program is indeed included in the MinGW binary directory but
its called mingw32-make.exe. You should _copy_ it to the same dir but
name it make.exe!
Re: CDT does not build my projects: Build Error [message #68693 is a reply to message #68190] Tue, 06 May 2003 03:39 Go to previous messageGo to next message
> objects = hello.o
> hello : $(objects)
^^^^ Shouldnt that be hello.exe??
^^^^^ Replace that with $@
> gcc -c hello.cpp
> all :
> ${MAKE} hello
> PHONY : clean
^^^^^ the . infront missing! should be .PHONY
put this above your rules and add the all and debug rule like
.PHONY: all debug clean
> clean :
> Build Error
Re: CDT does not build my projects: Build Error [message #68766 is a reply to message #68684] Tue, 06 May 2003 13:11 Go to previous message
> > C:\\msys\\1.0\\bin)
> name it make.exe!
Ahhhhh..., thank you very much then. (What's the diff anyway?)
Previous Topic:Reports on CDT 1.1.0
Next Topic:C/C Projects View Failure
Current Time: Wed Oct 15 14:06:52 EDT 2025
Powered by FUDForum. Page generated in 0.03685 seconds
