Home » Newcomers » Newcomers » Installer of the designed application
Installer of the designed application [message #687551] Wed, 22 June 2011 14:04 Go to next message
Hello All,
How is the product designed using the eclipse is delivered to the end user?
Can we create the installer of the designed product?
Re: Installer of the designed application [message #687594 is a reply to message #687551] Wed, 22 June 2011 15:39 Go to previous messageGo to next message
On 22-Jun-11 12:04, mallikarjun wrote:
> Hello All,
Eclipse is distributed as an archive. It's not installed in the Windows
sense nor is it typically installed via Linux/Unix package manager. You
just download, explode and then run.
Re: Installer of the designed application [message #687729 is a reply to message #687594] Thu, 23 June 2011 01:20 Go to previous messageGo to next message
Yes.Eclipse is distributed as an archive but I want to deploy the RCP application designed in the eclipse environment. How can I create the installer of the product??
Re: Installer of the designed application [message #688741 is a reply to message #687729] Sat, 25 June 2011 11:01 Go to previous messageGo to next message
I apologize for not being able to answer. We're just not on the same
wavelength. You should take a little more time doing basic things in
Eclipse so that you can couch your more complicated, unanswered
questions in terms others here will understand. If you're talking RCP,
I'd suggest doing the RCP tutorial from http://www.vogella.de.
Re: Installer of the designed application [message #689865 is a reply to message #687729] Tue, 28 June 2011 10:06 Go to previous message
However you want. There's nothing in Eclipse to support installation of
RCP apps, so you're free to use any installer technology that meets your
needs. An RCP app is just a directory structure, so just about any
installer technology can easily deal with it.
Eric
Previous Topic:Connecting to MS Team Foundation Server from eclipse, any free tool
Next Topic:How to use Meld with Eclipse?
Current Time: Thu Jul 24 22:35:16 EDT 2025
Powered by FUDForum. Page generated in 0.08017 seconds
