Home » Modeling » EMF » [CDO] Retrieve EstructuralFeature corresponding to InternalCDORevision#getContainingFeatureId()
[CDO] Retrieve EstructuralFeature corresponding to InternalCDORevision#getContainingFeatureId() [message #687581] |
Wed, 22 June 2011 15:19  |
Hi all,
I need to retrieve the feature corresponding to InternalCDORevision#getContainingFeatureId().
I have tried different methods to retrieve the feature but got unexpected results and so would like to check the correctness of my current approach.
Initially, I was trying to retrieve the feature as shown in the code below, before noticing that the feature returned differed from the expected result, expected result is to retrieve the feature equivalent to calling the eObject.eContainingFeature() with eObject being the EObject representing the CDORevision revision.
final int containingFeatureID = revision.getContainingFeatureID() < 0 ? InternalEObject.EOPPOSITE_FEATURE_BASE - revision.getContainingFeatureID() : revision.getContainingFeatureID();
InternalCDORevision parent = retrieveRevisionById((CDOID)revision.getContainerID());
feature = parent.getEClass().getEStructuralFeature(containingFeatureID);
I noticed that the feature returned would always be the EOpposite of the expected result (when its an EReference with an EOpposite), so my question is whether it would be correct to assume that the expected return value would always be the EOpposite if the feature retrieved is an EReference and has an EOpposite ?
Is there any further conditions that I am not aware of in order to correctly retrieve this feature ?
Thanks a lot,
Abdel
Re: [CDO] Retrieve EstructuralFeature corresponding to InternalCDORevision#getContainingFeatureId() [message #688064 is a reply to message #687794] |
Thu, 23 June 2011 16:02   |
Hi Eike,
After your response I have tried to write a unit test to show what I meant.
Given that the definition provided above seem equivalent to the return value of eContainingFeature from EObject interface (Returns the particular feature of the container that actually holds the object or null if there is no container) and is also the expected result I was refering to in my original post, I have written a unit test to compare the returned value for an EObject on client side and for a cdo revision on server side.
After making some more tests on other models, I can see that you definition also corresponds to the behaviour of cdo in most cases, while I was writing the unit test I realized that the issue might be related to the model used, so I tried to trim the model to a minimum in order to show what I meant.
I attached an ecore model to this post and I am providing you with my unit test, in order to reproduce what I now believe is an issue.
The return index for getContainingFeatureID on CDORevision returns the EOppossite of the feature used to refer to the CallableUnit.
So the expected value is the codeElement Structural Feature, but the returned value is module (which is its EOpposite). I have tested this on a new workspace by regenerating the model code for the ecore model provided, we use CDO version 3.0.
Please review and let me know what you think,
I'm also wondering under which conditions the returned value for the call to CDORevision#getContainingFeatureID() will be negative and how to treat it when it's the case.
Thanks a lot,
import org.eclipse.emf.cdo.common.id.CDOID;
import org.eclipse.emf.cdo.common.revision.CDORevision;
import org.eclipse.emf.cdo.common.util.CDOQueryInfo;
import org.eclipse.emf.cdo.eresource.CDOResource;
import org.eclipse.emf.cdo.internal.server.mem.MEMStore;
import org.eclipse.emf.cdo.net4j.CDONet4jUtil;
import org.eclipse.emf.cdo.net4j.CDOSessionConfiguration;
import org.eclipse.emf.cdo.server.CDOServerUtil;
import org.eclipse.emf.cdo.server.IQueryContext;
import org.eclipse.emf.cdo.server.IQueryHandler;
import org.eclipse.emf.cdo.server.IRepository;
import org.eclipse.emf.cdo.server.IStore;
import org.eclipse.emf.cdo.server.net4j.CDONet4jServerUtil;
import org.eclipse.emf.cdo.session.CDOSession;
import org.eclipse.emf.cdo.spi.common.revision.InternalCDORevision;
import org.eclipse.emf.cdo.spi.server.QueryHandlerFactory;
import org.eclipse.emf.cdo.transaction.CDOTransaction;
import org.eclipse.emf.cdo.util.CDOUtil;
import org.eclipse.emf.cdo.util.CommitException;
import org.eclipse.emf.cdo.view.CDOQuery;
import org.eclipse.emf.cdo.view.CDOView;
import org.eclipse.emf.ecore.EStructuralFeature;
import org.eclipse.net4j.Net4jUtil;
import org.eclipse.net4j.connector.IConnector;
import org.eclipse.net4j.internal.util.container.PluginContainer;
import org.eclipse.net4j.jvm.IJVMAcceptor;
import org.eclipse.net4j.jvm.IJVMConnector;
import org.eclipse.net4j.jvm.JVMUtil;
import org.eclipse.net4j.util.container.IManagedContainer;
import org.junit.BeforeClass;
import org.junit.Test;
public class TestContainingEFeatureCDO {
private static CDOSession session = null;
private static String queryLanguage = "eContainingFeature";
private static final String QUERY_CONTEXT = "context";
private static final String REPOSITORY_NAME = "repo1";
@BeforeClass
public static void prepareTest(){
final IManagedContainer container = PluginContainer.getInstance();
Net4jUtil.prepareContainer(container); // Prepare the Net4j kernel
JVMUtil.prepareContainer(container); // Prepare the JVM transport
CDONet4jServerUtil.prepareContainer(container); // Prepare the CDO
// server
CDONet4jUtil.prepareContainer(container); // Prepare the CDO client
container.activate();
container.putElement(QueryHandlerFactory.PRODUCT_GROUP,queryLanguage, null, new EContainingFeatureHandler());
IJVMAcceptor acceptor = JVMUtil.getAcceptor(container, "default"); // Start the
final IRepository repo = createRepository();
CDOServerUtil.addRepository(container, repo); // Start a CDO
IJVMConnector connector = JVMUtil.getConnector(container, "default"); // Open
session = openSession(connector);// Open a CDO session
private static CDOSession openSession(IConnector connector2) {
final CDOSessionConfiguration configuration = CDONet4jUtil.createSessionConfiguration();
configuration.setConnector(connector2);
configuration.setRepositoryName(REPOSITORY_NAME);
return configuration.openSession();
private static IRepository createRepository() {
final Map<String, String> props = new HashMap<String, String>();
IRepository repository = CDOServerUtil.createRepository(REPOSITORY_NAME, createMemStore(), props);
return repository;
private static IStore createMemStore() {
return new MEMStore();
static class EContainingFeatureHandler implements IQueryHandler{
public void executeQuery(CDOQueryInfo info, IQueryContext context) {
final IStore store = context.getView().getRepository().getStore();
final Map<String, Object> params = info.getParameters();
final CDOID queryContext = (CDOID)params.get(QUERY_CONTEXT);
final InternalCDORevision revision = (InternalCDORevision)store.getRepository().getRevisionManager()
.getRevision(queryContext, context, CDORevision.UNCHUNKED, CDORevision.DEPTH_NONE, true);
int containingFeatureId = revision.getContainingFeatureID();
CDOID containerID = (CDOID)revision.getContainerID();
final InternalCDORevision container = (InternalCDORevision)store.getRepository().getRevisionManager()
.getRevision(containerID, context, CDORevision.UNCHUNKED, CDORevision.DEPTH_NONE, true);
EStructuralFeature feature = container.getEClass().getEStructuralFeature(containingFeatureId);
System.out.println(feature.getName());
context.addResult(feature.getName());
@Test
public void testContainingFeature() throws CommitException {
CompilationUnit compUnit = CodeFactory.eINSTANCE.createCompilationUnit();
CallableUnit cu = CodeFactory.eINSTANCE.createCallableUnit();
compUnit.getCodeElement().add(cu);
CDOTransaction trans = session.openTransaction();
CDOResource resource = trans.getOrCreateResource("testRez");
resource.getContents().add(compUnit);
trans.commit();
EStructuralFeature feature = cu.eContainingFeature();
CDOView view = session.openView();
CDOQuery query = view.createQuery(queryLanguage, "");
query.setParameter(QUERY_CONTEXT, CDOUtil.getCDOObject(cu).cdoID());
List<String> results = query.getResult(String.class);
assertEquals(1, results.size());
assertEquals(feature.getName(), results.get(0));
Re: [CDO] Retrieve EstructuralFeature corresponding to InternalCDORevision#getContainingFeatureId() [message #688178 is a reply to message #688064] |
Fri, 24 June 2011 01:08   |
Hi Kaab,
I want to use the test code you've provided but I can't do it right now. Can you please open a proper bugzilla for your problem and attach all relevant files?
Cheers
/Eike
http://www.esc-net.de
Am 23.06.2011 22:02, schrieb kaab:
> Hi Eike,
> Thanks a lot,
> @BeforeClass
> // server
> return repository;
> @Override
> @Test
> trans.commit();
Current Time: Sun Jul 27 01:57:34 EDT 2025
Powered by FUDForum. Page generated in 0.04478 seconds
