Home » Modeling » EMF » [CDO] CDO Hibernate Server causes " Not able to update container columns of CDOResource wit
[CDO] CDO Hibernate Server causes " Not able to update container columns of CDOResource wit [message #687213] Thu, 16 June 2011 12:24 Go to next message
SHORT STORY
When starting CDO Hibernate Server I get
"Not able to update container columns of CDOResource with id
OID:http://www.eclipse.org/emf/CDO/Eresource/4.0.0#CDOResource#1"
LONG STORY
I want to get started with a current installation of CDO Hibernate Store.
I installed Eclipse 3.7RC4
+ Hibernate 3.6.0
+ CDO Model Repository SDK 4.0.0
+ EMF Teneo CDO SDK 1.2.0
+ CDO Model Repository Server Hibernate 4.0.0
+ some other plugins
(Mostly following instructions at
http://wiki.eclipse.org/CDO/Hibernate_Store/Quick_Start)
I then checked out example projects from
http://dev.eclipse.org/svnroot/modeling/org.eclipse.emf.cdo/trunk/plugins/org.eclipse.emf.cdo.examples.*
I added
org.hsqldb;bundle-version="1.8.1"
to the MANIFEST.MF to get around a class not found error.
Then, when running
org.eclipse.emf.cdo.examples.hibernate.server/CDOHibernateServer.launch
again I get the error message
Any hints?
Goetz
----------------excerpt from console log ----------------------
[ERROR] Not able to update container columns of CDOResource with id
java.lang.IllegalStateException: Not able to update container columns of
CDOResource with id
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernateStoreAccessor.repairResourceIDs(HibernateStoreAccessor.java:746)
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernateStoreAccessor.doWrite(HibernateStoreAccessor.java:669)
at
org.eclipse.emf.cdo.spi.server.StoreAccessorBase.write(StoreAccessorBase.java:149)
at
org.eclipse.emf.cdo.internal.server.TransactionCommitContext.write(TransactionCommitContext.java:425)
at
org.eclipse.emf.cdo.internal.server.Repository.initRootResource(Repository.java:1449)
at
org.eclipse.emf.cdo.internal.server.Repository.doActivate(Repository.java:1562)
at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycle.java:72)
at
org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:99)
at
org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:89)
at
org.eclipse.emf.cdo.server.CDOServerUtil.addRepository(CDOServerUtil.java:201)
at
org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.configure(RepositoryConfigurator.java:110)
at
org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplication.doStart(CDOServerApplication.java:61)
at org.eclipse.net4j.util.om.OSGiApplication.start(OSGiApplication.java:61)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at
org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run(AnyThreadAppLauncher.java:26)
CDOResource with id
at
at
at
at
at
at
at
at
at
at
at
at
at
Re: [CDO] CDO Hibernate Server causes " Not able to update container columns of CDOResource [message #687215 is a reply to message #687213] Thu, 16 June 2011 12:32 Go to previous messageGo to next message
On 16/06/2011 17:24, Goetz Botterweck wrote:
> SHORT STORY
I do not know if this is related to the problem, but after switching to
a different database (Microsoft SQL Server) I now get the error messages
pasted below.
Could this be caused by combining the incompatible versions of the
various plugins?
[ERROR] Unable to instantiate default tuplizer
[org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDORevisionTuplizer]
org.hibernate.HibernateException: Unable to instantiate default tuplizer
at
org.hibernate.tuple.entity.EntityTuplizerFactory.constructTuplizer(EntityTuplizerFactory.java:108)
at
[... lines deleted...]
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at
Caused by: java.lang.NoSuchMethodError:
org.hibernate.proxy.ProxyFactory.postInstantiate(Ljava/lang/String;Ljava/lang/Class;Ljava/util/Set;Ljava/lang/reflect/Method;Ljava/lang/reflect/Method;Lorg/hibernate/type/AbstractComponentType;)V
at
org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDORevisionTuplizer.buildProxyFactory(CDORevisionTuplizer.java:301)
at
org.hibernate.tuple.entity.AbstractEntityTuplizer.<init>(AbstractEntityTuplizer.java:167)
at
org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDORevisionTuplizer.<init>(CDORevisionTuplizer.java:59)
... 30 more
Re: [CDO] CDO Hibernate Server causes &quot; Not able to update container columns of CDOResource [message #687217 is a reply to message #687215] Thu, 16 June 2011 12:50 Go to previous messageGo to next message
Hi Goetz,
This must indeed be related to wrong hibernate/cdo hibernate versions.
gr. Martin
>> SHORT STORY
> pasted below.
> various plugins?
> at
> at
> at
> at
> at
> at
> ... 30 more
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [CDO] CDO Hibernate Server causes &quot; Not able to update container columns of CDOResource [message #687222 is a reply to message #687213] Thu, 16 June 2011 14:45 Go to previous messageGo to next message
Hi Goetz,
I have encountered this error also, but now it does not occur with me. It is this bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=345816
I committed a change for this bugzilla on the 15th of may, but I can't imagine that your version is older (if it is
rc4). Can you check the build date of the cdo.server.hibernate plugin (it is reflected in the version qualifier of the
plugin)?
gr. Martin
On 06/16/2011 06:24 PM, Goetz Botterweck wrote:
> SHORT STORY
> LONG STORY
> + Hibernate 3.6.0
> I added
> Then, when running
> Any hints?
> Goetz
> CDOResource with id
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> CDOResource with id
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
The Netherlands
Re: [CDO] CDO Hibernate Server causes &quot; Not able to update container columns of CDOResource [message #687225 is a reply to message #687222] Thu, 16 June 2011 15:43 Go to previous messageGo to next message
On 16/06/2011 19:45, Martin Taal wrote:
> Hi Goetz,
> imagine that your version is older (if it is rc4). Can you check the
> version qualifier of the plugin)?
For some reason that was a version from April. I started an update (Help
> Check for Updates) and was offered a new version from 2011-06-07.
Now the problem is gone :)
Thanks.
Re: [CDO] CDO Hibernate Server causes &quot; Not able to update container columns of CDOResource [message #687226 is a reply to message #687225] Thu, 16 June 2011 16:33 Go to previous message
Good to hear, it was kind of an annoying issue to find... So happy that it is not back :-).
gr. Martin
>> Hi Goetz,
> Thanks.
The Netherlands
Re: [CDO] CDO Hibernate Server causes &quot; Not able to update container columns of CDOResource [message #687490 is a reply to message #687213] Thu, 16 June 2011 12:32 Go to previous message
> SHORT STORY
pasted below.
various plugins?
at
at
at
at
at
at
... 30 more
Re: [CDO] CDO Hibernate Server causes &quot; Not able to update container columns of CDOResource [message #687492 is a reply to message #687215] Thu, 16 June 2011 12:50 Go to previous message
Hi Goetz,
gr. Martin
>> SHORT STORY
> pasted below.
> various plugins?
> at
> at
> at
> at
> at
> at
> ... 30 more
The Netherlands
Re: [CDO] CDO Hibernate Server causes &quot; Not able to update container columns of CDOResource [message #687497 is a reply to message #687213] Thu, 16 June 2011 14:45 Go to previous message
Hi Goetz,
plugin)?
gr. Martin
> SHORT STORY
> LONG STORY
> + Hibernate 3.6.0
> I added
> Then, when running
> Any hints?
> Goetz
> CDOResource with id
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> CDOResource with id
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
The Netherlands
Re: [CDO] CDO Hibernate Server causes &quot; Not able to update container columns of CDOResource [message #687501 is a reply to message #687222] Thu, 16 June 2011 15:43 Go to previous message
> Hi Goetz,
Thanks.
Re: [CDO] CDO Hibernate Server causes &quot; Not able to update container columns of CDOResource [message #687502 is a reply to message #687225] Thu, 16 June 2011 16:33 Go to previous message
gr. Martin
>> Hi Goetz,
> Thanks.
The Netherlands
Previous Topic:(no subject)
Next Topic:[CDO] Getting started with CDO Hibernate Store
Current Time: Sat Jul 26 06:18:55 EDT 2025
Powered by FUDForum. Page generated in 0.05749 seconds
