Home » Modeling » EMF » Delegates for creating instances of data types
Delegates for creating instances of data types [message #687091] |
Sun, 29 May 2011 11:18  |
Originally posted by:
I've been using EMF delegates for some time and they are great for
interactively enriching a model with Javascript or OCL. There is one
thing I miss, however, and that is the ability to create instances of an
EDataType. This should allow creating an instance from a String and
converting it back, using two expressions (or body statements) in
appropriate annotations. This kind of delegate should used by the
standard factory, so you have the choice of either adding the
annotations or generating and implementing the createXXXFromString and
convertXXToString.
If this makes sense, I can try to implement it and submit the code for
review by the EMF team.
Hallvard
Re: Delegates for creating instances of data types [message #687098 is a reply to message #687096] |
Mon, 30 May 2011 05:37   |
Hi Hallvard
>> I'm not suggesting that you use UML, just understand the EAnnotations
>> that UML2Ecore already uses so that you avoid another duplication
>> similar to that by the EMF invocation delegate annotation of the
>> GenModel operation body annotation.
> You mean we should reuse an eAnnotation source and key pair if this is
> already somehow supported by UML2Ecore, to avoid getting yet another
> pair. Perhaps someone with knowledge about this can tell us if this is
> the case?
Most, perhaps all, of the Ecore annotations are described in the EMF
book, but the EMF delegates are not and the UML annotations are not.
I think someone, ?? you ??, would be doing a great service by greping
all *.jet* files in EMF and UML2 for anything that looks like an
EAnnotation source, and then creating a wiki page mapping source URI to
genmodel functionality. We could then retrofit reference documentation
and API contracts on what each EAnnotation source URI means, rather than
rely on examples of how to solve XSD and UML problems.
Ed Willink
Re: Delegates for creating instances of data types [message #687102 is a reply to message #687101] |
Mon, 30 May 2011 11:25  |
On 30.05.11 17.06, Ed Merks wrote:
> We could add reflective support for more common patterns; it doesn't
> seem likely thought that we could cover them all.
In many cases, there isn't an natural/obvious text format, so you'll
have to invent one for the sake of the model. That's why a pluggable
delegate makes sense. I hope someone has time to look at the attachment.
I could take it further, e.g. make a complete patch, but I would like an
evaluation of the current suggestion first.
>> I have create this bugzilla and attached to it an experimental
>> implementation that works with js4emf:
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=347611
Hallvard
Re: Delegates for creating instances of data types [message #687309 is a reply to message #687091] |
Sun, 29 May 2011 11:56  |
Hi Hallvard
Do you mean that you want to be able to program the body of e.g.
convertXXToString in the Ecore model?
FromString is specific to EDataType which cannot have a special
operation so I guess it just needs to be an agreed EAnnotation.
ToString is more general; you might allow customisation of toString for
all EClassifiers, but again I guess it just needs to be an agreed
EAnnotation.
You need to check the UML2Ecore conversion carefully because there is a
surprising amount of generation capability for UML and you might find
that what you want is already more than 90% implemented.
Ed Willink
On 29/05/2011 16:18, Hallvard Trætteberg wrote:
> an EDataType. This should allow creating an instance from a String and
> convertXXToString.
> Hallvard
Re: Delegates for creating instances of data types [message #687311 is a reply to message #687092] |
Sun, 29 May 2011 16:46  |
> EAnnotation.
Yes, the idea is to define two annotations for an EDataType, one for the
body of convertXXXToString and one for the body of createXXXFromString
(similar to the annotation for an EOperation body). Then you can use
your favorite scripting language (currently OCL and very soon
Javascript) to support custom EDataTypes without generating the factory
code and implementing it in Java.
I'm not using UML, hence I want Ecore to support it directly.
Hallvard
Re: Delegates for creating instances of data types [message #687312 is a reply to message #687093] |
Sun, 29 May 2011 21:21  |
Hallvard,
It does make sense. Ideally we'd have something that even works for
dynamic models. Of course there is already reflective support that
looks for a String constructor (or valueOf method) and calls toString,
but if it's a class over which you have no control, that doesn't really
help.
>> EAnnotation.
> the body of convertXXXToString and one for the body of
> createXXXFromString (similar to the annotation for an EOperation
> body). Then you can use your favorite scripting language (currently
> OCL and very soon Javascript) to support custom EDataTypes without
> generating the factory code and implementing it in Java.
> Hallvard
Re: Delegates for creating instances of data types [message #687315 is a reply to message #687093] |
Mon, 30 May 2011 03:09  |
Hi Hallvard
I'm planning to get direct OCL to Java generation going in an
intermediate OCL 3.2 release. This will cut out the parsing overheads
and much of the run-time dispatch overheads by directly calling the OCL
library operations. This needs integration with genmodel. Perhaps it is
similar to something you need.
I perhaps misunderstood a comment at the Eclipse Summit that IIRC EEF
are migrating EMF's JET scripts to M2M. If so, it would be good to try
to exploit this so that the added-value EAnnotation functionality was in
identifiable modules rather than woven into obscure places.
Ed
Re: Delegates for creating instances of data types [message #687319 is a reply to message #687095] |
Mon, 30 May 2011 04:51  |
the case?
Not at this point, but could be in the future.
Hallvard
Re: Delegates for creating instances of data types [message #687320 is a reply to message #687094] |
Mon, 30 May 2011 05:12  |
> dynamic models. Of course there is already reflective support that looks
> for a String constructor (or valueOf method) and calls toString, but if
> it's a class over which you have no control, that doesn't really help.
E.g. java.net.URI has a static create method.
Hallvard
Re: Delegates for creating instances of data types [message #687321 is a reply to message #687096] |
Hi Hallvard
> the case?
Ed Willink
Re: Delegates for creating instances of data types [message #687326 is a reply to message #687097] |
Mon, 30 May 2011 11:06  |
Hallvard,
> Hallvard
Re: Delegates for creating instances of data types [message #687327 is a reply to message #687101] |
Hallvard
Current Time: Wed Jul 23 19:11:36 EDT 2025
Powered by FUDForum. Page generated in 0.06562 seconds
