Home » Modeling » EMF » Pretty Print
Pretty Print [message #673578] Tue, 24 May 2011 03:31 Go to next message
Is there any helper to do a pretty print of an EObject instance, that would print its attributes and contents recursively in a human-readable format (not XML, and without going through the Resource mechanism)? The purpose is to log it, so it should have no side-effect.
David
Re: Pretty Print [message #687039 is a reply to message #673578] Tue, 24 May 2011 09:38 Go to previous messageGo to next message
David,
No there isn't. Such a thing could be quite huge; I'm not sure it would
make sense to log so much...
> David
Re: Pretty Print [message #687041 is a reply to message #687039] Tue, 24 May 2011 12:34 Go to previous messageGo to next message
Hi Ed
Are you sure there isn't? I thought the reflective printer in the OCL
Console was borrowed from Ecore. It has a very small amount of code
wrapping the provision of an IItemLabelProvider by a
ReflectiveItemProviderAdapterFactory. See
org.eclipse.ocl.examples.interpreter.console.OCLConsolePage.toString(Object).
Or, there is also HUTN that I understand forms part of the Epsilon project.
Or, there's custom code that I wouldn't have thought would be as much as
50 lines.
Ed Willink
On 24/05/2011 14:38, Ed Merks wrote:
> David,
> would make sense to log so much...
>> side-effect.
>> Thanks,
>> David
Re: Pretty Print [message #687043 is a reply to message #687041] Wed, 25 May 2011 03:28 Go to previous messageGo to next message
Ed,
Well, there isn't one in EMF. :-P I'm not sure what's everywhere else...
The comment about size was about the size of what's printed for logging
purposes, not about the size of the code to produce it.
Ed Willink wrote:
> Hi Ed
> project.
> as 50 lines.
> Regards
> Ed Willink
>> David,
>>> side-effect.
>>> Thanks,
>>> David
[CDO] memoryanalyzer [message #687049 is a reply to message #687043] Wed, 25 May 2011 06:33 Go to previous messageGo to next message
is the Eclipse memoryanalyer project the correct tool to analyse memory
behavior of CDO models? CDO has its own garbage collector, so reports
could be more useful if CDO is explicitely handled, could they not?
Is there a static method to force to garbage collect all CDO model
elements which can be garbage collected (like System.gc() in Java)?
Is there a static method to get an iterator over all CDO model elements?
And for one such model element (which is not garbage collected), is it
possible to know the reason why it is not garbage collected?
A last question: I want to add a new CDO element to the contents of an
CLEAN CDO element, so if I do this, is the whole content list retrieved
from the database only to add the element to the list, or can I say to
the CDO server: "add this new element to the containment feature of this
persistent element". I dont want to "check out" the containment list on
client side, since even though it may contain only CDO proxies, the list
may be sized several gigs.
Re: [CDO] memoryanalyzer [message #687051 is a reply to message #687049] Wed, 25 May 2011 07:18 Go to previous messageGo to next message
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
Am 25.05.2011 12:33, schrieb exquisitus:
<blockquote cite="mid:irilf3$b34$1@news.eclipse.org" type="cite">
<div class="moz-text-flowed" style="font-family: -moz-fixed;
font-size: 14px;" lang="x-unicode">is the Eclipse memoryanalyer
project the correct tool to analyse memory behavior of CDO
models? </div>
</blockquote>
I don't know that tool, yet.<br>
<br>
font-size: 14px;" lang="x-unicode">CDO has its own garbage
collector, </div>
</blockquote>
No, it does not. It only implements the references between EObjects
(and some other more internal classes) in a way that the normal JVM
garbage collector can reclaim them once the application does not
reference them anymore.<br>
<br>
font-size: 14px;" lang="x-unicode">so reports
<br>
</div>
</blockquote>
I don't see how or why.<br>
<br>
<br>
model
<br>
</div>
</blockquote>
No.<br>
<br>
<br>
elements? And for one such model element (which is not garbage
collected), is it
<br>
</div>
</blockquote>
If I don't miss something there are exactly 3 conditions that
prevent a CDOObject from being garbage collected:<br>
<br>
1) The application holds on this object.<br>
2) You've called
CDOView.Options.setCacheReferenceType(ReferenceType.STRONG)<br>
3) You're using EObject adapters in combination with
CDOView.Options.setStrongReferencePolicy(CDOAdapterPolicy)<br>
<br>
You have read access to the internal objects map of a CDOView
through InternalCDOView.getObjects().<br>
<br>
<br>
of an CLEAN CDO element, so if I do this, is the whole content
list retrieved from the database only to add the element to the
list, or  can I say to the CDO server: "add this new element to
the containment feature of this persistent element". I dont want
to "check out" the containment list on client side, since even
<br>
</div>
</blockquote>
With partial collection loading you could avoid to fill the list
with proper CDOIDs but, as you've noticed, it will be filled with
(non-singleton) marker elements. You may be interested in this
bugzilla, although there's no effort planned in the near future:<br>
<br>
214477: Better CDORevision list implementation for UNINITIALIZED
data<br>
<a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=214477">https://bugs.eclipse.org/bugs/show_bug.cgi?id=214477</a><br>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<a class="moz-txt-link-freetext" href="http://www.esc-net.de">http://www.esc-net.de</a><br>
<a class="moz-txt-link-freetext" href="http://thegordian.blogspot.com">http://thegordian.blogspot.com</a><br>
<a class="moz-txt-link-freetext" href="http://twitter.com/eikestepper">http://twitter.com/eikestepper</a><br>
<br>
<br>
</body>
</html>
Re: [CDO] memoryanalyzer [message #687061 is a reply to message #687051] Thu, 26 May 2011 06:19 Go to previous messageGo to next message
Can you say how big in bytes one such marker element is?
What exactly can be garbage collected from one CDO element? features
independently? String typed features? a reference list? or only single
references in the reference list?
An maximal garbage-collected CDO element would only contain the CDOID
and a revision number? if the CDO element has an attribute "name" of
type String, and I call getName() once: can the name string be garbage
collected and the CDO element not?
Re: Pretty Print [message #687240 is a reply to message #673578] Tue, 24 May 2011 09:38 Go to previous messageGo to next message
David,
> David
Re: Pretty Print [message #687243 is a reply to message #687039] Tue, 24 May 2011 12:34 Go to previous messageGo to next message
Hi Ed
50 lines.
Ed Willink
> David,
>> side-effect.
>> Thanks,
>> David
Re: Pretty Print [message #687245 is a reply to message #687041] Wed, 25 May 2011 03:28 Go to previous messageGo to next message
Ed,
Ed Willink wrote:
> Hi Ed
> project.
> as 50 lines.
> Regards
> Ed Willink
>> David,
>>> side-effect.
>>> Thanks,
>>> David
[CDO] memoryanalyzer [message #687252 is a reply to message #687043] Wed, 25 May 2011 06:33 Go to previous messageGo to next message
Re: [CDO] memoryanalyzer [message #687254 is a reply to message #687049] Wed, 25 May 2011 07:18 Go to previous messageGo to next message
<html>
<head>
</head>
models? </div>
</blockquote>
<br>
collector, </div>
</blockquote>
<br>
<br>
</div>
</blockquote>
<br>
<br>
model
<br>
</div>
</blockquote>
No.<br>
<br>
<br>
collected), is it
<br>
</div>
</blockquote>
<br>
2) You've called
<br>
<br>
<br>
<br>
</div>
</blockquote>
<br>
data<br>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<br>
<br>
</body>
</html>
Re: [CDO] memoryanalyzer [message #687266 is a reply to message #687051] Thu, 26 May 2011 06:19 Go to previous messageGo to next message
Re: Pretty Print [message #985477 is a reply to message #673578] Thu, 15 November 2012 07:29 Go to previous message
This is an old topic, I know, but since it is googles first hit when searching for "EMF pretty print" I'll just post my solution here so that others won't have to do it all over.
It's just some java thrown together to pretty-print an EMF model tree. When used in combination with junit Assert.equals(String, String) you're a double-click away from having the differences in your model highlighted in red, without using EMF.compare. Can be used for logging purposes as well.
A simplified use case:
@Test
public void areModelsEqual() {
  EObject o1 = ...;
  EObject o2 = ...;
  if(!ECoreUtils.equals(o1, o2)) {
    assertEquals(PrettyPrinter.prettyPrint(o1), PrettyPrinter.prettyPrint(o2));
    fail("different objects, but same pretty print output");
And here the printer:
import java.util.ArrayList;
import java.util.List;
import org.eclipse.emf.ecore.EClass;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.EStructuralFeature;
public class PrettyPrinter {
	private static final String INDENT = "    "; //$NON-NLS-1$
	public static String prettyPrint(EObject object) {
		List<String> lines = prettyPrintAny(object, ""); //$NON-NLS-1$
		StringBuilder sb = new StringBuilder();
		for (String line : lines) {
			sb.append(line).append('\n');
		return sb.toString();
	private static List<String> prettyPrintAny(Object o, String indent) {
		List<String> lines = new ArrayList<>();
		if (o instanceof EObject) {
			EObject object = (EObject) o;
			EClass eClass = object.eClass();
			lines.add(eClass.getName() + " [" + o.getClass().getCanonicalName() + "] {"); //$NON-NLS-1$ //$NON-NLS-2$
			lines.addAll(prettyPrintRecursive(object, INDENT));
			lines.add("}"); //$NON-NLS-1$
		} else if (o instanceof Iterable) {
			lines.add("["); //$NON-NLS-1$
			for (Object obj : (Iterable<?>) o) {
				lines.addAll(prettyPrintAny(obj, INDENT));
			lines.add("]"); //$NON-NLS-1$
		} else {
			String line = String.valueOf(o) + ' ';
			if (o != null) {
				line += '[' + o.getClass().getCanonicalName() + ']';
			lines.add(line);
		return indentLines(lines, indent);
	private static List<String> indentLines(List<String> lines, String indent) {
		List<String> result = new ArrayList<>();
		for (String l : lines) {
			result.add(indent + l);
		return result;
	private static List<String> prettyPrintRecursive(EObject o, String indent) {
		EClass eClass = o.eClass();
		for (EStructuralFeature feature : eClass.getEAllStructuralFeatures()) {
			Object value = o.eGet(feature);
			String line = feature.getName() + " = "; //$NON-NLS-1$
			List<String> list = prettyPrintAny(value, INDENT);
			list.set(0, list.get(0).trim());
			result.add(line + list.get(0));
			list.remove(0);
			result.addAll(list);
		return indentLines(result, indent);
Hope this will help somebody.
[Updated on: Thu, 15 November 2012 07:53] by Moderator
Previous Topic:[CDO] CDO and transaction isolation levels
Next Topic:boolean qualify in getCreateChildText
Current Time: Fri Jul 25 21:21:10 EDT 2025
Powered by FUDForum. Page generated in 0.05962 seconds
